Newbie brain teaser - Router Forums
post #1 of 17 (permalink) Old 12-14-2009, 03:41 PM Thread Starter
Default Newbie brain teaser
I need to make angled slots in the ends of 3/4" square stock. The slots are 5/32" wide and 7/8" long at an angle of 65 degrees.
I can make one slot fine with two cuts on the bandsaw but I am stumped on how to make the other slot which is 65 degrees in the other direction. My Delta bansaw only tilts that far in one direction.
I know there must be a simple answer to this problem, but I can't find it!
fishlore is offline
post #2 of 17 (permalink) Old 12-14-2009, 05:44 PM
First Name: Bob
Hi fishlore, you didn't say how deep for the grooves or how long the piece is that you need the ends slotted... but can you rig up some type of carriage sled to rest the piece on when running across your router table fence?
anotherBob is offline
post #3 of 17 (permalink) Old 12-14-2009, 07:52 PM
Ghidrah's Avatar
First Name: Ronald
Your BS tilts to 65? I probably got this all wrong but if the 2/65 cuts are made in the 3/4" ends of the board, you could do it on a table saw with a standard miter gauge. Stand them up, blade height at 7/8" and run them through.
Ghidrah is offline
post #4 of 17 (permalink) Old 12-14-2009, 08:37 PM
just waiting for someone to pop in..
post #5 of 17 (permalink) Old 12-14-2009, 09:08 PM
First Name: Drew
If you rotate the stock 180 degrees about its long axis you can use the same setup.
Drew Eckhardt is offline
post #6 of 17 (permalink) Old 12-15-2009, 02:44 AM
Dejure's Avatar
First Name: Kelly
Can you cut a wedge and use carpet tape to hold it in position for the second. It works well on corbels and others cuts that require the cut out piece of wood to stay in place for the next cut.
The reason I have what you want is, I never lent it out before.
Scraps are a myth.
Dejure is offline
post #7 of 17 (permalink) Old 12-15-2009, 06:52 AM Thread Starter
The grooves are 7/8" long and the piece, which has to have a groove cut in each end, is only 3" long. My router table only holds bits 90 degrees. I can chamfer but I can't cut a slot at a 65 degree angle. I'm sure I'm missing something obvious here, but I don't know what it is.
fishlore is offline
post #8 of 17 (permalink) Old 12-15-2009, 07:24 AM
Trimax's Avatar
First Name: Curt
I think not sure but if you rotate the miter in the oppsite direction to 115deg
that will give you the angle. I think this is what your wanting the oppsite angle is 65deg
of course Im baseing this on a table saw which should be a easier cut.
Trimax is offline
post #9 of 17 (permalink) Old 12-15-2009, 08:00 AM
Jig it vertical on tablesaw with tennon jig
bagofdonuts88 is offline
post #10 of 17 (permalink) Old 12-17-2009, 12:10 PM
First Name: Mischa
Default Like Drew said...
... if you rotate the right picture by 180 degrees, you'll get the left one. So just rotate your piece by 180 degrees. In other words: your cuts have two-fold rotational symmetry around the vertical axis ,
Edit: sorry make that horizontal axis. I guess a jig is in order
Cheers! MM
xvimbi is offline
Newbie larry32138 New Member Introductions 7 08-31-2011 01:54 AM
Newbie member/ Ancient brain The Sculptors Studio New Member Introductions 3 02-28-2009 07:22 PM
Advice- Newbie to Newbie rstermer General Routing 4 05-28-2008 06:25 AM
Newbie to all goad New Member Introductions 7 01-14-2008 11:18 PM
Newbie Here Paul Stroik New Member Introductions 3 09-29-2006 07:46 AM
