Sharpening jig - Router Forums
post #1 of 5 (permalink) Old 12-21-2009, 06:09 AM Thread Starter
AxlMyk's Avatar
Default Sharpening jig
Anyone have one of these? Comments?
General Tools Chisel & Plane Blade Sharpener - 809 at The Home Depot
Can't be too bad for $20. General makes good stuff.
AxlMyk is offline
post #2 of 5 (permalink) Old 12-21-2009, 07:04 AM
That jig should make the Scary-sharp method easy. I say go for it Mike.
post #3 of 5 (permalink) Old 12-21-2009, 07:16 AM
Price seems fine, and any guide that you can maintain your angle should be great.
No matter what you get, I recommend using a bevel gauge or protractor to confirm the angle tho'.
I have a similar honing guide, and it along with my brass bevel gauge are always in my tool bag.
Wild Horse is offline
post #4 of 5 (permalink) Old 12-21-2009, 08:13 AM
Gene Howe's Avatar
First Name: Gene
I have one similar to the General. Also have the one in the link below.
The Veritas (below) is really sweet!
Veritas® Mk.II Honing Guide - Lee Valley Tools
Gene Howe is online now
post #5 of 5 (permalink) Old 12-21-2009, 10:15 AM
First Name: Bob
Hi AxlMyk,
I think that one would be my third choice... ranked, and here's why:
1) Honing Guide at Woodcraft - $12.99
Buy Honing Guide at Woodcraft.com
It's dead simple to ensure that you will have your edge at a perfect 90°, just tighten the jaws. Also the cheapest. Microbevels are easy too, just loosen, slide what you are honing down a tad, re-tighten, hone. It will accept chisels as small as 1/16" too.
2) The cadillac that pkni mentioned/linked to. I have the older guide set from Veritas:
It's easy to get a mirobevel using it, a little tricky sometimes making sure that it's at a perfect 90° though. Hopefully pkni can comment as to whether that was made easier in the newer Mark II setup... I dunno.
3) General Tools Chisel & Plane Blade Sharpener you linked to. Although the price seems not bad, by looking at it, I'd be afraid that applying too much downwards pressure when honing, might open the angle... spoiling the edge. Like I said... just looking at it, never used it... suppose if you are really careful using it, it would be better than free handing it. Can't imagine trying to free hand hone a 1/8" chisel, much less putting a secondary bevel on it... guess some folks are really good.
anotherBob is offline
Sharpening BIts tbagjohn Router Bits - Types and Usage 6 12-22-2009 09:53 PM
sharpening bits and circular blades SE18 Tools and Woodworking 0 10-13-2009 07:27 AM
Sharpening (NOT router bits) reikimaster Tools and Woodworking 11 03-28-2009 07:25 PM
jijs for sharpening chancy682 New Member Introductions 4 02-13-2009 06:44 PM
Sharpening Router Bits bbibbins General Routing 0 07-31-2008 10:29 PM
