MFD Rings Glue? - Router Forums
post #1 of 8 (permalink) Old 12-26-2009, 09:00 PM Thread Starter
First Name: Timmy
Default MFD Rings Glue?
First of all thanks for looking at my question!
I am making subwoofer rings by using my router to make the rings as well as to round off the edge for a cleaner look (using this for fiberglassing an enclosure)
What i am wondering is, do I need nails/screws to hold the two rings together permanently or is the glue sufficient? Iv heard that the glue is actually what holds the rings together; the nails are just there to hold them steady while the glue dries.
Anyone have any experience with this? Thanks for your time!
Here is a picture of the ring I made for practice:
silentblackhat is offline
post #2 of 8 (permalink) Old 12-26-2009, 09:34 PM
kp91's Avatar
First Name: Doug
the glue is enough
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 8 (permalink) Old 12-26-2009, 09:34 PM
RouterForums.com User
harrysin's Avatar
First Name: Harry
The ring shown looks perfect. Modern adhesives give a joint that is stronger than the material, just clamping whilst setting is required.
Bobj3, the forums expert on most things has a son who makes these rings, I think for auto use and Bob has shown posts in the past and I'm sure that when he tumbles out of bed and heats up the house, he'll give you all the advice that you require.
So that we know a little about members whose questions we answer, it would be nice, also helpful if you were to fill in your profile, this is aimed at all members who have failed to do this.
Harry
harrysin is offline
post #4 of 8 (permalink) Old 12-26-2009, 09:50 PM
Hi
You did a fine job glue is all that's needed,you don't want any nails or screws, they will show up like a sore thumb..this is the 1st.thing that people look at..
post #5 of 8 (permalink) Old 12-26-2009, 10:26 PM Thread Starter
First Name: Timmy
Thanks for the advice, I will fill the profile out now.
Hi
Thanks. I was thinking of putting the screws on the bottom side so its not visible but after everyone's advice, I will leave it the way it is. I wish I could use this ring that I made...but to make it look better, im going to use a rounded 1/2" ring on top and the 3/4 ring where the sub mounts.
Thanks again!
post #6 of 8 (permalink) Old 12-27-2009, 06:21 AM
BigJimAK's Avatar
The other possibility would be to make it out of one piece and just dado out the 1/4" relief. With that technique, there's be nothing to glue.
Otherwise I agree... glue will hold it, as long as your tolerances are good (not too large of a gap between the rings, yet enough not to glue-starve the joint).
BigJimAK is offline
post #7 of 8 (permalink) Old 12-27-2009, 06:48 AM
Mike Wingate's Avatar
First Name: mike
I made some 4 1/4" MDF rings for speakers on the lathe. Plenty of dust, I reversed them to the rounded front profile
by paper wedging them onto a disc, mounted on a faceplate. Then I cut the rear rebate. I was quite surprised how easy it was, and how delicate they were without breaking. All sprayed black with a metal grill in the rear rebate between speaker and ring.
Mike Wingate is offline
post #8 of 8 (permalink) Old 12-27-2009, 08:45 AM
harrysin's Avatar
First Name: Harry
Thank you for filling out your profile Kevin, for such a young man you sure do keep yourself busy, as we say downunder, goodonya.
Harry
harrysin is offline
Hello stephan New Member Introductions 7 10-17-2011 01:40 PM
Hot melt glue to hold small parts for pattern routing? rstermer Portable Routing 22 06-22-2009 09:05 PM
Wanted: Looking for glue pot bobj3 Woodworking Classifieds 16 03-30-2009 07:46 AM
Biscuit or glue joint Ghidrah Router Bits - Types and Usage 13 11-13-2008 04:10 PM
Glue advice Router is still my name Tools and Woodworking 17 10-08-2006 10:18 AM
