Pin wrench spacing - Router Forums
post #1 of 9 (permalink) Old 12-28-2009, 05:02 PM Thread Starter
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Default Pin wrench spacing
Hi
You know the pin wrenches that come with angle grinders to turn the blade clamping nuts?
I've only got a small one (4") and the pins are not far enough apart for something else I'm wanting one for. Does anyone have a big angle grinder and could tell me what the pin centres are on the tool for it?
Cheers
Peter
istracpsboss is offline
post #2 of 9 (permalink) Old 12-28-2009, 05:39 PM
RustyW's Avatar
First Name: Rusty
You might try something adjustable.
https://www.equalizerfusion.com/Prod...dAWeOiWxMc1hGB
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
post #3 of 9 (permalink) Old 12-28-2009, 10:48 PM Thread Starter
Country: Croatia
First Name: Peter
Hi
Never heard the term spanner wrench before. Spanner as in spanning, I guess. I've got one of those somewhere amongst my engineering tools, but most of those are still in storeage. Thanks anyway !
Cheers
Peter
post #4 of 9 (permalink) Old 12-28-2009, 10:59 PM
Hi Peter
I have one of the tank size grinder (about 25 lbs) and the one I have uses the hex nut type..the one I have has a push in lock pin as well..if I recall it's a 7/8" or 1" hex nut size..
Originally Posted by istracpsboss View Post
Hi
Cheers
Peter
post #5 of 9 (permalink) Old 12-28-2009, 11:11 PM Thread Starter
Country: Croatia
First Name: Peter
Thanks Bob but my application needs a pin wrench. I can make one up, but if a bigger one than the one I've got is available, I'll go into town and grab one. I thought I'd just check first.
Cheers
Peter
post #6 of 9 (permalink) Old 12-28-2009, 11:17 PM
RStaron's Avatar
First Name: Ron
Peter the larger angle grinders use hex nuts to hold the wheel on. Your best bet would be what Rusty shows.
A person can never have too many tools!
RStaron is offline
post #7 of 9 (permalink) Old 12-28-2009, 11:26 PM
Hi Peter
Not to sure if they sale Snap-On tools in your town, but they do sale one that looks like a big pair of snap ring tools..but making one is easy as you know..
Cheers
Peter
post #8 of 9 (permalink) Old 01-04-2010, 07:31 AM Thread Starter
Country: Croatia
First Name: Peter
Hi Peter
Hi Bob
I reckon the only Snap-On tools around here are in my toolbox. I've an Armstrong adjustable somewhere. (Two arms pivoted at one end with pins on the extremities) I think it is probably in store with all my engineering stuff, though. I've knocked up one out of a strip of oak and two M5 bolts that will do pro temp.
Cheers
Peter
post #9 of 9 (permalink) Old 01-04-2010, 11:11 AM
Sounds good Peter
If you use a old Crescent Wrench ( adjustable wrench) and drill two holes for some 1/8" steel dowel pins , you have one that will fit many tools
Hi Bob
Cheers
Peter
Two wrench method- one wrench router Delta6mike General Routing 68 03-26-2012 09:25 AM
Spacing question twisted bit Guide Bushings and Templates 1 12-04-2009 12:44 AM
Strange Wrench!! Birch Tools and Woodworking 23 07-20-2009 06:13 AM
Dovetail Spacing Calculations FlyMaster Table-mounted Routing 15 05-24-2007 04:30 PM
Hitachi MV12 two wrench system cbsjoez1935 Table-mounted Routing 15 04-22-2007 05:51 AM
