Scoll Saw - Router Forums
post #1 of 9 (permalink) Old 01-03-2010, 01:26 PM Thread Starter
First Name: Denise
Default Scoll Saw
I am looking to purchase a scoll saw. under $400.
Any advice on choose a manufacturer + model ?
LAM23M
lam23m is offline
post #2 of 9 (permalink) Old 01-03-2010, 02:06 PM
Gene Howe's Avatar
First Name: Gene
A bit over $400, but, not much more.
Dewalt
Gene Howe is online now
post #3 of 9 (permalink) Old 01-03-2010, 02:24 PM
First Name: Duane
Harbor freeght, $80.00.
Duane867 is offline
post #4 of 9 (permalink) Old 01-03-2010, 03:37 PM Thread Starter
First Name: Denise
scolls sggestions from $500+ - $80 any thoughts for somewhere in between.
I am a beginner but want something that will last.
LAM23M
lam23m is offline
post #5 of 9 (permalink) Old 01-03-2010, 03:56 PM
Mike Wingate's Avatar
First Name: mike
What use will you be puting this saw too? What materials will you be cutting? How often will you use it? My first saw, a Dremel was poor. My next was the most expensive piece of kit in the workshop at the time. It has stood over 20 years of use. I do not cut wood thicker than 1" I have 2 bandsaws for that. I cut 1/4" steel with the right blades (shotgun and crossbow triggers) Tonight I cut an ellipse template out of 1/4" lexan without it melting and rejoining. I cut veneers between layers of ply. Mother of pearl inlay. Rubber, carbon fibre, 1/2" alloy plate.etc. This machine is a Hegner. I have also used Delta's, Jet (branded Axminster in the U.K). My Hegner works, is quiet, does not vibrate, cuts vertically at all times with the correct blades, has easy blade changes. Look at the machines that the scrollsawers on the net use (Scrollsaw Workshop ). Or those that you see churning out quality at craft shows. Buy once, buy well.
Mike Wingate is offline
post #6 of 9 (permalink) Old 01-03-2010, 04:56 PM
First Name: Duane
I own the Harbor freight saw and its pretty good for the money.
the table is a little small and a little light duty. butt is an $80 saw ya know.
It suits my needs though.
You can check craigs list for an older craftsman scroll saw as well.
The older tables are cast and sturdy.
http://cincinnati.craigslist.org/tls/1519830478.html
Duane867 is offline
post #7 of 9 (permalink) Old 01-03-2010, 05:22 PM
AlanZ's Avatar
First Name: Alan
Denise,
I have the Dewalt scroll saw... you're more than welcome to come here and play with it... we're likely located ear each other. I bought mine on craigslist, so I got a bargain. But even at retail it's considered one of the best scroll saws for the money.
Triton 2.25 router; CMT Industrio table; Jointech fence; SC planer; Dewalt miter; Delta 14" bandsaw; Festool TS55, MFT/3, CT22, ETS150/3, OF1400, PSB300EQ; Dewalt Scrollsaw; Lathes: Nova DVR XP, Delta 46-460; JJ-6CS jointer, Ridgid OSS; Grizzly 1023s cabinetsaw
AlanZ is offline
post #8 of 9 (permalink) Old 01-03-2010, 05:36 PM
Hi Denise
If you are in Denver Colorado you can have this one free if you pick it up..
Just like the one in the link below that's not saying to much..it's a old Craftsman that I replace with the DeWalt
Sears/Craftsman 16" Variable Speed Scroll Saw
post #9 of 9 (permalink) Old 01-03-2010, 11:06 PM
kp91's Avatar
First Name: Doug
Denise,
I have had good luck with the Delta Q-3 saws. The last one I bought was about $200 on craigslist.
There are always a bunch of scrollsaws on craigslist, it seems.
1 John 1:9
Fredericksburg, VA
kp91 is offline
Need to find out motor voltage for Delta 40-601 Scoll saw ven0msho Wood Scrolling 2 12-17-2009 08:34 AM
