Problem with Porter Cable 892 router - Router Forums
post #1 of 7 (permalink) Old 01-04-2010, 08:45 AM Thread Starter
First Name: Trent
Default Problem with Porter Cable 892 router
I have a PC 892 router in my router table and have been having increasing difficulty adjusting the bit. Whenever I raise the bit it begins to bind and I can see the bit lean over to the side as the motor cocks sideways in the fixed base.
I pulled the base off and cleaned out all the saw dust and brushed out the teeth in the adjuster. When I put it back together it moves a little easier but still is off. I find that the increased tension causes the blade to not only be cocked a little sidways screwing up the cut, while it is running the router will right itself causing the blade to straighten and the bit height to rise.
Anyone else seen this? This router is only a few months old and has not seen a lot of work.
It is attached to an WoodPecker aluminum insert plate and it is not the plate flexing.
the_nite_owl is offline
post #2 of 7 (permalink) Old 01-04-2010, 08:55 AM
AxlMyk's Avatar
Take it out of the base and clean the sawdust out.
The base has a tendency to collect it in the gears.
AxlMyk is offline
post #3 of 7 (permalink) Old 01-04-2010, 09:26 AM Thread Starter
First Name: Trent
As I said above, I have already done that. It seems that the motor itself is binding up on one side of the fixed base and not sliding easily.
post #4 of 7 (permalink) Old 02-15-2011, 08:31 PM
First Name: Chuck
You might have the router taken to a Porter Cable repair center. I don't know how long you have had the router but you may be able to have it covered under warranty. It sound like mabe you might have a bearing issue or mable the armature shaft may be bent.
cmsmith55 is offline
post #5 of 7 (permalink) Old 03-05-2011, 03:37 AM
First Name: rebecca
Never faced any problem like that but yes if in future i face this kind of problem then i am very much aware of it !!
rebeccaasmit is offline
post #6 of 7 (permalink) Old 03-06-2011, 10:11 AM
First Name: Danny
I have the same router in my table, but I have mine mounted in a woodpecker lift, so I can't say what the problem is.
Maybe try cleaning everything again and then coating it with a dry lube like graphite or some thing like that.
Danny.
jd99 is offline
post #7 of 7 (permalink) Old 03-06-2011, 09:31 PM
First Name: Warren
Have been using the same router for past five years and more without a problem-other than the original plunge base. I think you have a defect in the router motor and base assembly. I'd call nearest PC repair center.....find one easily.
I'm betting that is what is wrong.
sourdough is offline
Problem mounting Dewalt Router to Caftsman Table Saw apollo2000 General Routing 15 01-26-2015 02:30 AM
Bosch 1617vs Verses 690 Porter cable Glenmore Tool Reviews 20 08-09-2009 09:36 PM
No CD-ROM with Porter Cable 890 Router Combo Kit? Mort_Stevens Table-mounted Routing 11 08-29-2006 12:44 PM
Porter Cable router jig table mount Phil Swearingen Jigs and Fixtures 0 11-06-2005 11:19 AM
