Best joint for a childs bed rail? - Router Forums
post #1 of 5 (permalink) Old 01-06-2010, 01:25 PM Thread Starter
First Name: Trent
Default Best joint for a childs bed rail?
I want to make a bed rail to help prevent my grandson from rolling out of bed when he stays over at our house. I need to make a piece that slips under the mattress and turns 90 deg up to hold the railing across the side of the bed.
What would be the best joint to use on this 90 deg angle that would be strong enough to support this type of use?
Would box joints have enough strength for this? Probably with 3/4" pine?
Anyone done anything similar?
the_nite_owl is offline
post #2 of 5 (permalink) Old 01-06-2010, 02:27 PM
BigJimAK's Avatar
Glued box joints would be plenty strong. It doesn't need to support his weight, just the roll-over factor. If it were me I'd make the "L" narrow on the under-mattress side and screw it to a thin piece of plywood (?1/4"?), perhaps 12"-16" wide, to ensure his weight was on the horizontal part before his body pressed outward on the side. Then his own body weight will help hold it in place.
I wouldn't finish the under-bed part, as I'd want it to remain rough to avoid being slippery.
BigJimAK is offline
post #3 of 5 (permalink) Old 01-06-2010, 02:42 PM
Hi Trent
I would suggest thought type dovetail joint. it's a lock joint so to speak once it assemble almost impossible to bend over with all the mass of the dovetails..also you don't need to glue them up, with a 3/16" to 1/4" dowel pin down the center of the dovetails ,it's locked and you can pull the pin out to put it away for some other day..
post #4 of 5 (permalink) Old 01-06-2010, 08:13 PM
BigJimAK's Avatar
I like your idea, BJ!
BigJimAK is offline
post #5 of 5 (permalink) Old 01-06-2010, 09:21 PM Thread Starter
First Name: Trent
I like the idea of the dovetail joints also but I have no experience with them or any jigs for creating them so i think I will have to go with box joints for now and maybe improve on it in the future when I have more experience (and tools) to do it with.
If for any reason it seems too weak I can always add a third corner for the extra strength.
Thanks guys.
Rail and Stile alignment....HELP arkwood Router Bits - Types and Usage 15 07-11-2011 05:16 PM
The first through dovetail joint by AKEDA Benny LaBaw Jigs and Fixtures 9 12-14-2009 08:01 AM
rail coping jig electricmurph Jigs and Fixtures 24 03-17-2009 06:30 AM
Incra half blind joint S Bolton Jigs and Fixtures 7 10-23-2007 01:38 PM
Stile & Rail Bit DougO Router Bits - Types and Usage 7 07-11-2007 08:42 PM
