Reverse rotation router - Router Forums
 12Likes
post #1 of 25 (permalink) Old 01-09-2010, 09:14 PM Thread Starter
First Name: B.J.
Default Reverse rotation router
I am building a duplicator that will cut two pieces at one time. I am trying to find a router that counter spins so I will have one router spinning clockwise and the other counter clockwise.
I have had no luck finding one. I know they are available but can't find any. I have read up a little on reversing the spin on a router but I am not sure if that is the route I want to go. Safety reasons and all.
Thanks.
mach2_man is offline
post #2 of 25 (permalink) Old 01-09-2010, 09:44 PM
Hi BJ
Sounds like you are looking for more of a elec. mixer than a router the kind they use to make cakes,etc...
Thanks.
post #3 of 25 (permalink) Old 01-09-2010, 11:21 PM
First Name: Paul
Im new to routing and wood working in general so please don't point and laugh if this is silly, but would having one router mounted from under and one above in theory reverse the directly it will be feeding from and work in the same fashion? like I say if its a completely silly idea just ignore me lol
gmercer_48083 likes this.
Dont forget to live life for fear of death grasp each day and live it to it full otherwise it is pointless.
newwoodworker is offline
post #4 of 25 (permalink) Old 01-09-2010, 11:26 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums B.J. Glad to have you join us.
Dave
the "Doctor"
Dr.Zook is offline
post #5 of 25 (permalink) Old 01-09-2010, 11:42 PM
RustyW's Avatar
First Name: Rusty
Have you had any luck finding bits that cut the opposite direction?
MEBCWD likes this.
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
post #6 of 25 (permalink) Old 01-10-2010, 12:04 AM Thread Starter
First Name: B.J.
The reason it won't work is because it will be incredibly complicated to build, will take up tons of space on the table, if it was an open bottom it would be plausible but I am using a downdraft dust collection. There would also be the issue of how it cuts. Since I will be cutting 3 dimensional from the top it would be nearly impossible to get the proper cut if one of the blanks were to be cut from the bottom, and then I would still have to worry about the swing issue, one would be swinging down towards the blank and the other would be swinging away from the blank.
I had not thought of this option previously, it made me stop and think. But then I realized the guy I have building the dupe machine would strangle me if I came out with a change like that.
This was going to be another topic but since you brought it up. The only way to get reverse directional router bits would be to have them custom made.
I came across Saburr Tooth bits and the pics look like they might be dual directional, but their website stinks so I was not able to look around. They seem to have good reviews but could not find any actual experienced reviews.
If anyone knows of a place that supplies quality bits that do both directions, I don't like to mix brands on a project like this, I would be very grateful.
Thank you for the welcome.
post #7 of 25 (permalink) Old 01-10-2010, 07:54 AM
AxlMyk's Avatar
There are no routers that turn in the opposite direction. Period.
Bits would cost a fortune to have made.
AxlMyk is offline
post #8 of 25 (permalink) Old 01-10-2010, 08:28 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Reversing a universal (brush type) motor isn't a problem, just reverse the field connections relative to the brushes. The problem arises with the cutter, it would have to be custom made, unlike twist drills which are available for both directions and are used in industry where many holes are drilled at the one time, some going clockwise others anti-clockwise.
Harry
harrysin is offline
post #9 of 25 (permalink) Old 01-10-2010, 08:41 AM
Gene Howe's Avatar
First Name: Gene
Well, now. I thought everything turned opposite directions depending on which side of the equator you were on. Naw..airplanes would fall out of the sky...or fly backwards.
Seriously, I'm glad you abandoned the idea. Even if it were economically possible, it would seem to be incredibly dangerous.
Gene
Gene Howe is offline
post #10 of 25 (permalink) Old 01-10-2010, 09:28 AM
Hi BJ
They now make and sell a power hand saw just that way maybe it time they may do the same for the router but I don't think so right now..
They do it all the time in the big wood mill shops but with 2 or more router motors..lots of luck with your quest..
Rigid Model R2900 Router Combo and Ryobi Model A25RT02 Router table bigdave720 Table-mounted Routing 12 04-05-2012 07:27 PM
How do I mount a Router to a table demaX Table-mounted Routing 3 04-16-2009 06:56 AM
Sears Plunge Router Model 315.275110 Wally99 Table-mounted Routing 3 12-24-2008 06:39 AM
