column lubrication??? - Router Forums
post #1 of 78 (permalink) Old 01-12-2010, 06:42 AM Thread Starter
allthunbs's Avatar
First Name: Ron
Default column lubrication???
Ok, here's the problem...
I have two plunge routers and the plunge action needs to be lubricated but I don't want to use anything that attracts dirt or dust because the columns will get plugged to the point of uselessness.
1. how do you clean your plunge columns?
2. what do you use to lubricate them?
3. have you modified your router in some way to "adjust" to a job and if so, how?
4. do you inventory parts and change them out or do you "go to bust" and then fix it?
5. do you do your own repairs or take them to a "specialist?"
6. what are the common repairs that you effect yourself?
7. are there things that you do to your router that you think others could also be able to do?
thanks for the help.
Allthunbs
allthunbs is offline
post #2 of 78 (permalink) Old 01-12-2010, 07:24 AM
harrysin's Avatar
First Name: Harry
Ron, whenever the plunge starts to tighten I dismantle the router, give everything a thorough clean and rub in the minutest amount of CRC then reassemble. Normally I would do my own repairs, but as my main two routers are made by MAKITA, repairs are seldom required in spite of my heavy usage. The only improvements to my routers has been making a six step depth of cut adjuster which makes deep plunge routing in 4mm steps a breeze. Then there was the external light, later changed to an illuminated base which is literally "brilliant". I blow compressed air through the routers regularly.
Harry
harrysin is offline
post #3 of 78 (permalink) Old 01-12-2010, 08:45 AM Thread Starter
allthunbs's Avatar
First Name: Ron
Thanks Harry:
Originally Posted by harrysin View Post
...rub in the minutest amount of CRC then reassemble. Normally I would do my own repairs, but as my main two routers are made by MAKITA, repairs are seldom required in spite of my heavy usage. The only improvements to my routers has been making a six step depth of cut adjuster which makes deep plunge routing in 4mm steps a breeze. Then there was the external light, later changed to an illuminated base which is literally "brilliant". I blow compressed air through the routers regularly.
What's "CRC?"
Thanks Harry. I'll add all your improvements to the list.
Ron
Allthunbs
post #4 of 78 (permalink) Old 01-12-2010, 09:10 AM
dustmaker's Avatar
First Name: Frank
You definitely want to use a dry lubricant. I have had pretty good success with using past wax on the columns. Regardless of what you use, sawdust will conspire to break it down over time and repeated lubes will be necessary. I always disassemble, blow out the debris and re-wax. Works for me.
- Frank
Woodworking is more than a hobby.
It is a journey of discovery,
An application of innovation and creativity,
And an opportunity at self improvement.
dustmaker is offline
post #5 of 78 (permalink) Old 01-12-2010, 09:30 AM
First Name: George
Take the plunge springs out, clean the tubes and parts that slide. The key is to get that sucker clean, I mean real clean..Then I use dry film graphite to lube the internals...
Works for me..
Good Luck.
George Cole
George II is offline
post #6 of 78 (permalink) Old 01-12-2010, 12:04 PM
dutchman 46's Avatar
First Name: Howard
I try to stay away from any lube. If you can take it apart, and clean and rub out the columns with polish, sparingly, it works well also. The springs on my router are the only thing that has lube, and that is a grease put in at the factory, and i haven't removed it. Its used for hand held. I am not sure of the other plunge, It Hans,t needed anything, as of yet.
John 3:16
dutchman 46 is offline
post #7 of 78 (permalink) Old 01-12-2010, 04:21 PM Thread Starter
allthunbs's Avatar
First Name: Ron
Works for me..
Good Luck.
George Cole
Hi George:
Thanks. do you have a brand name for the graphite or a supplier?
Allthunbs
post #8 of 78 (permalink) Old 01-12-2010, 04:23 PM Thread Starter
allthunbs's Avatar
First Name: Ron
Hi Howard:
Which polish? On my bikes I use a thin film teflon but I haven't been able to find it for years.
Thanks for the contribution.
Allthunbs
post #9 of 78 (permalink) Old 01-12-2010, 04:25 PM Thread Starter
allthunbs's Avatar
First Name: Ron
Hi Frank:
paste wax as in Johnson's floor wax or do you have something else in mind?
Thanks for the input.
Allthunbs
post #10 of 78 (permalink) Old 01-12-2010, 04:52 PM
Just a butt in post
I think Harry is talking about this type
Synthetic Lubricants - Potential Applications And Markets In Western Europe, North America, And Asia-Pacific (Technical Insights)
Thanks Harry:
What's "CRC?"
Ron
lubrication beckchest New Member Introductions 4 12-03-2009 07:47 AM
Lubrication on posts? jw2170 Table-mounted Routing 8 07-14-2009 08:37 AM
Making a fixture for column Gene Pinner Jigs and Fixtures 4 09-12-2006 09:46 AM
Guide Rod Lubrication routerjohn Tools and Woodworking 6 03-03-2006 10:26 PM
