Chipping/Tear out/Pitting? on round over on an edge - Page 2 - Router Forums
 13Likes
post #11 of 18 (permalink) Old 11-26-2018, 07:33 PM
fmakrancy's Avatar
Welcome N/A
you using a table or free hand routering???
suggest you climb cut...
I am using a Lowes Router Table with above table fine adjustment option.
fmakrancy is offline
post #12 of 18 (permalink) Old 11-26-2018, 08:05 PM
fmakrancy's Avatar
Welcome N/A
Thank you Stick486 and everyone else who replied! I was VERY surprised to log back on to see 4 replies to my question all in less than 24 hours!!! As a novice with only Jr. High wood shop training -it's nice to have people be so helpful!
I think that the climb cut setup might be a bit much as I am making 40 pieces every two weeks in a production capacity -plus I don't want to lose any fingers! (My wife would never let me go back out into my shop if that happened! Based on all the reading, and input from your replies -I think that I am going to make a A zero-clearance auxiliary fence. The opening for the router bit as it is now is the width of the entire bit plus about 1/8 inch on each side. The support is not the greatest and the plastic mitre gauge is not very long either -AND there is about 1/16 inch of play in as it sits in the mitre slot. I am starting to understand the benefits of spending more money on the tools that I am buying! I used MDF to lengthen the mitre gauge basically out of the box. I am pretty sure I have some 3/4" oak that I can make a new mitre gauge extension and a zero-clearance auxiliary fence. I should be able to use the clamp system that came with the router table to hold it all in place. I'll let you all know my progress when I get to it in a few weeks. I posted pictures of what I am making -thought maybe it will help in case I missed something in my explanation of the problem.
Thanks again everyone! I think I am going to like it here
Last edited by fmakrancy; 11-26-2018 at 08:16 PM. Reason: Answered my own question -duh!!!
post #13 of 18 (permalink) Old 11-26-2018, 08:34 PM
to cut the zero clearance in the fence - let the bit do it..
slide the fence into the bit up to the bearing...
mark the bearing's location...
make a cut out for it..
w/ all that play and slop you have in your equipment it's a no wonder you are experiencing tearout..
Herb Stoops likes this.
post #14 of 18 (permalink) Old 11-26-2018, 08:35 PM
FWIW...
Pine is notorious for wild grain...
DaninVan likes this.
post #15 of 18 (permalink) Old 11-26-2018, 10:39 PM
gdonham1's Avatar
First Name: Guy
When routing end grain it is always ready to tear out. If you are routing end grain always route that first. If you have a little corner tear out the pass on the long grain will many times cover it up. If possible route the end grain first but clamp or otherwise back up the corner with another board that is clamped or hot glued or carpet taped. If your project is repetitive then make a jig that would clamp to your project. Unsupported end grain on the right side of a board is very easy to tear out because the router is spinning against the grain and on the right corner there is nothing to keep the grain from flying off. So backup the corner and your problem will go away.
If backing up the corner is not practical then start by climb cutting (routing backwards) for just a little on the corner and see if that improves your cut quality. Climb cutting can be hazardous because your router tries to run away. Plus the bit is still turning in the direction to knock off the grain of the wood on the corner.
But most importantly route the end grain first and usually the long grain route will cover up any tear out. As others pointed the smaller the bit diameter the faster the router should run. Make multiple passes when ever possible. By making multiple passes you are removing less material each time and you get a smoother cut quality. Sharp bits are always required. A diamond stone on the flat of the bit will touch up slightly worn bits but if you have ran hundreds of feet of lumber over a bit then it is time to chunk it and buy a new one.
gdonham1 is offline
post #16 of 18 (permalink) Old 12-11-2018, 01:49 AM
fmakrancy's Avatar
So I also have another theory on what I think is tear out and I am now wondering if my problem is actually tear out or if it is just crappy lumber. I was at Menards -where I purchase all of the lumber for these bottle openers and took the picture below thinking someone on this forum could shed some light on the subject. I buy this lumber in 4X6, 4X8, 4X10, or 4X12. The length i choose all depends on the end grain that is visible in the picture. I will choose the end grain with the least amount of pitting that is the least warped in whichever length meets these requirements and then cut to length in my shop that my wife constantly reminds me is just a garage. every once and a while I will luck out and find one that has no pitting on either side of the grain and is very straight -but it is a rarity. I have been told that when the wood is pitted like in the picture below, it is because it was harvested too young and was waterlogged (for lack of a better word) over its short life. When I have no choice and have orders that must be fulfilled, I will purchase this pitted wood if good non-pitted lumber is unavailable on the shelf. When I cut it down into 10.5 inch lengths and compare it to a non-pitted piece of the same length, the weight difference can be anywhere between 20% - 25%. Does anyone think that the problem I could be experiencing could be more of a lumber issue and less of an equipment issue? Thought I would ask just to get an expert opinion on the subject... Thanks in advance!
-Fred
Name:	pitted wood.jpeg
post #17 of 18 (permalink) Old 12-11-2018, 10:58 AM
It may be indicative of boards that are more prone to do it. Trees, particularly evergreens, grow early wood (spring and early summer) and late wood (late summer and early fall). The smoother bands of end grain are late wood which is denser and harder than the early wood. The early wood is what is tearing out. You might have better luck by picking out the boards with the widest early growth bands showing. Eliminating the ones which had the worst tearout from the trim saws might help too but that might have just been the difference between a sharp trim saw and a dull one.
DaninVan and Herb Stoops like this.
post #18 of 18 (permalink) Old 02-02-2019, 12:46 PM
fmakrancy's Avatar
I solved the tear out problem that I was having! I am not sure exactly it the problem was the fence or the mitreguage or a combination of both. I ended up trying to run the wood through not relying on the mitre gauge and realized that the more pressure I put on the bearing as I slid my work through, the less pitting there would be. Once I stopped using the miter gauge and fence altogether and put a medium amount of pressure on the wood against the bearing, my pieces all turned out with zero pitting/tearout! I am including a picture of the unsanded -nearly finished product as it came right off the table. I am ecstatic! My life just got so much easier! Thank you to all who contributed input to my problem! Love this forum!!!
Looking to commission woodworker for round end table Hockeystyx Tools and Woodworking 1 10-26-2009 10:14 AM
finger joint bit for edge to edge atmartin23 Router Bits - Types and Usage 20 09-04-2009 01:51 PM
Laminate counter with oak edge kefjens General Routing 13 03-27-2009 04:37 PM
routing edge on round tom41 Jigs and Fixtures 34 01-06-2009 08:19 PM
Groove in edge of curved piece imrichb Router Bits - Types and Usage 5 07-06-2007 02:03 PM
