Chipping/Tear out/Pitting? on round over on an edge - Router Forums
 13Likes
post #1 of 18 (permalink) Old 01-16-2010, 04:29 AM Thread Starter
First Name: Bernard
Default Chipping/Tear out/Pitting? on round over on an edge
Anyone have tips to prevent chipping/tear out/pitting/whatever its called when rounding over perpendicular to the grain? First time for me using actual wood, been working with just MDF for small projects before. The wood is pine and I'm using a ryobi 1/2" round over bit and a Hitachi M12VC router in the fixed base. Here's a picture of edge with the pitting (hopefully it shows).
Any help will be greatly appreciated. Thanks.
-Bernard
bbmonster is offline
post #2 of 18 (permalink) Old 01-16-2010, 08:09 PM
allthunbs's Avatar
First Name: Ron
-Bernard
We've got a whole bunch of names but tear-out is appropriate.
Use a sharp bit. Don't be so aggressive with your cuts. Take smaller "bites." Starting from the right make shallow divots every few inches to the left then, route from left to right. use a straight edge guide rather than a bearing. Don't cut to final dimensions, sneak up on it. Come close and finish with sand paper. Even scrapers can't help when end grain is going all over the place. BTW, keeping different size bearings in your bit kit will help "adjust" the depth of cut to allow for stuff like this.
The experts will be along shortly to correct my babble and give you the real goods. This is just to push your query back up to the top of the stack.
Allthunbs
allthunbs is offline
post #3 of 18 (permalink) Old 01-17-2010, 01:15 AM
xplorx4's Avatar
First Name: Jerry
Ditto Ron, try a better quality bit. I have used lesser quality bits and some of the better quality bits and the difference is night and day. Check out Router Bits – Rockler – Hundreds of Top-Quality Bits for Every Imaginable Purpose!, Oak Park Enterprises Ltd. - Router Table, Router, Router Bits, Router Jigs, Router Accessories: Home, MLCS Router Bits and Woodworking Products
Lamentations 3:22-23
xplorx4 is offline
post #4 of 18 (permalink) Old 01-17-2010, 01:26 AM
Hi Bernard
That's very common for pine ( softwoods) run the speed up on the router and make more than one pass.. 3 best for softwoods..
-Bernard
post #5 of 18 (permalink) Old 01-17-2010, 05:30 AM Thread Starter
First Name: Bernard
Thanks all. Will pick up a better round over bit and run the router at a higher speed (noticed I had the speed set at 1/2 max when I used it today). I took several passes, dropping the bit by 1/8" each time, so my guess my problem is the bit and speed.
post #6 of 18 (permalink) Old 11-26-2018, 02:55 AM
fmakrancy's Avatar
I am having the same problem. I have a production setup where I produce about 40 10" X 4" X 3/4" backings with 6 sides. I get the same exact issue, but always on only one side -which happens to be the left 45 degree angle at the top. Sanding is killing my fingers and extremely time consuming. I purchased brand new CMT orange bits and got away from the HFT junk I was using -but even with the brand new CMT Contractor orange ogee bit, I get the same issue on the same corner every time. I am ready to pull my hair out! I have tried making multiple passes -going to the extent of 5, sometimes 6 per time. Some are worse than others. My router does not have a speed control but it is a brand new Kobalt that I got from Lowes. The other 5 corners -including end grain are absolutely beautiful and require no sanding. Anyone have any other suggestions for my problem?
Thanks!
-Fred
fmakrancy is offline
post #7 of 18 (permalink) Old 11-26-2018, 03:05 AM
Welcome N/A
you using a table or free hand routering???
suggest you climb cut...
File Type: pdf R5 Climb-Cutting Versus Chip-Cutting.pdf (176.1 KB, 21 views)
File Type: pdf woodsmith-184-avoiding-router-table-tearout.pdf (292.2 KB, 22 views)
Semipro likes this.
"SNORK Mountain Congressional Library and Taxidermy
post #8 of 18 (permalink) Old 11-26-2018, 08:15 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Welcome N/A
some timbers especially Pine do tend to have that problem. As has been said, a sharp bit (which you have) must be combined with slow feed and has also been mentioned, a climb cut can be tried but if on a router table the work-piece must be held securely otherwise it can be flung across the shop. If handheld it must be clamped for the same reason.
Harry
harrysin is offline
post #9 of 18 (permalink) Old 11-26-2018, 12:01 PM
If you try the climb cut then I would rout most of the profile the regular way and then drop the bit just a fraction more and do the climb cut. The less material you take off that way the easier it will be to control the router.
harrysin, CharleyL and Semipro like this.
post #10 of 18 (permalink) Old 11-26-2018, 01:02 PM
All the above is good advice. If all else fails I would run it down to 1/32 proud and use a sanding block to finish up the one spot that is a problem. I have a set of sanding blocks made from the good parts of old belt sander belts that I use a lot on every project. They sure save the fingers. Soft woods tend to do that, the least little variation in the surface causes it to show up on the cut,and end grain can cut nicely in one direction and not the other,
dirt_dobber likes this.
Herb Stoops is offline
Looking to commission woodworker for round end table Hockeystyx Tools and Woodworking 1 10-26-2009 10:14 AM
finger joint bit for edge to edge atmartin23 Router Bits - Types and Usage 20 09-04-2009 01:51 PM
Laminate counter with oak edge kefjens General Routing 13 03-27-2009 04:37 PM
routing edge on round tom41 Jigs and Fixtures 34 01-06-2009 08:19 PM
Groove in edge of curved piece imrichb Router Bits - Types and Usage 5 07-06-2007 02:03 PM
