Shop Vac Water Filter - Router Forums
post #1 of 16 (permalink) Old 01-24-2010, 04:40 PM Thread Starter
Soapdish's Avatar
First Name: Jake
Default Shop Vac Water Filter
While this is not a new idea, many of you may have never seen anything like this. Thoughs of you who have or have seen the Rainbow vacuum knows that it uses water as the filter. While building our house and tired of cleaning/buying filters for my shop vac, I decided that I would figure out a way to make a water filter for it. My set-up uses the smaller shop vac and hose, a 5 gal bucket with a lid (the lid I use has a rubber seal in it), and some assorted pieces of shop vac hoses accessories. Drill 2 holes in the top of the lid just big enough for the hose connector to pop in. Then you will need to connect a long tube that will extend down into the bucket (about 2” from the bottom).The other tube will only extend down a few inches. Hook one hose to the shop vac and then to the SHORT tube. Hook up your other hose to the LONG tube…this will be the end you use.Now put enough water in the bucket to cover the end of the long tube by a few inches. The vac will pull a suction through the water, and all of the dust and dirt will be trapped in the water. I don’t have a whole shop vacuum system, and I hate paying $12 dollars for the pleated filters..This system works awesome. You will hear lots of bubbling and gurgling while it is running, and there will be some water carry over into the shop vac (so only use the foam sleeve). If you use this for Sheetrock dust cleanup (this is the best damn thing in the world for this BTW) you will need to clean the water out fairly frequently. For sawdust removal every few days (depending on how much you use it). Mine is not fancy or pretty, but it works fantastic. One of these days I will make a better one, fixing the water carry over issue, and I’ll put it on some sort of dolly so it can roll with the Vac. Check out the pictures. I hope this helps some one.
Oh, BTW, about 6 months after I made this thing, I saw something similar in the Sheetrock section at HD. It was only there for a short time, and I don’t think they sell it anymore, so much for me making any money off this idea.
My favorite thread on routerforums.com. Great Posts
Soapdish is offline
post #2 of 16 (permalink) Old 01-24-2010, 06:32 PM
Thumbs up
Looks like a great idea, just may put something like that together this weekend to give it a try.
John Schaben
jschaben is offline
post #3 of 16 (permalink) Old 01-24-2010, 07:30 PM
Hi Jake
That rig looks good ,nice job , but they have been around a long time for the 5 gal bucket
Dust Collection Accessories - Peachtree Woodworking Supply, Inc.
Originally Posted by Soapdish View Post
While this is not a new idea, many of you may have never seen anything like this. Thoughs of you who have or have seen the Rainbow vacuum knows that it uses water as the filter. While building our house and tired of cleaning/buying filters for my shop vac, I decided that I would figure out a way to make a water filter for it. My set-up uses the smaller shop vac and hose, a 5 gal bucket with a lid (the lid I use has a rubber seal in it), and some assorted pieces of shop vac hoses accessories. Drill 2 holes in the top of the lid just big enough for the hose connector to pop in. Then you will need to connect a long tube that will extend down into the bucket (about 2Ē from the bottom).The other tube will only extend down a few inches. Hook one hose to the shop vac and then to the SHORT tube. Hook up your other hose to the LONG tubeÖthis will be the end you use.Now put enough water in the bucket to cover the end of the long tube by a few inches. The vac will pull a suction through the water, and all of the dust and dirt will be trapped in the water. I donít have a whole shop vacuum system, and I hate paying $12 dollars for the pleated filters..This system works awesome. You will hear lots of bubbling and gurgling while it is running, and there will be some water carry over into the shop vac (so only use the foam sleeve). If you use this for Sheetrock dust cleanup (this is the best damn thing in the world for this BTW) you will need to clean the water out fairly frequently. For sawdust removal every few days (depending on how much you use it). Mine is not fancy or pretty, but it works fantastic. One of these days I will make a better one, fixing the water carry over issue, and Iíll put it on some sort of dolly so it can roll with the Vac. Check out the pictures. I hope this helps some one.
Oh, BTW, about 6 months after I made this thing, I saw something similar in the Sheetrock section at HD. It was only there for a short time, and I donít think they sell it anymore, so much for me making any money off this idea.
post #4 of 16 (permalink) Old 01-24-2010, 07:39 PM
Marco's Avatar
That's a very god idea for the Shop Vac dust colector's........ a few weeks back my shop vac got full and then half clogged before I realized why it was so dusty........ it looked like all of the dust that it could suck in was being blown out!!!! Your water filter would greatly hinder both of those from happening
Galatians 5:13
Marco is offline
post #5 of 16 (permalink) Old 01-24-2010, 07:45 PM Thread Starter
Soapdish's Avatar
First Name: Jake
Hi Jake
Bobj3, the link you provided only shows some sort of cyclone separator, not a water filter, different link maybe? With this setup, the the dirt and dust is carried with the suction through the water, and as a consequence stays in the water.
Soapdish is offline
post #6 of 16 (permalink) Old 01-24-2010, 07:51 PM
Noob's Avatar
First Name: Paulo
So the shop vac is connected to the short hose and the hose that is sucking up the whatever is connected to the long hose that is submerged under water?
Noob is offline
post #7 of 16 (permalink) Old 01-24-2010, 08:01 PM
Hi Jake
Yep, saw the long hose going in the bucket, the wet and dry vac.work the same way dirt and water go in and mix in the can but in the separator the dust goes to the vac. can or to say most of it but the hvy. stuff like chips and water are in the separator..
post #8 of 16 (permalink) Old 01-24-2010, 08:10 PM Thread Starter
Soapdish's Avatar
First Name: Jake
This thing bubbles like crazy (as you can imagine) and that's the reason there is some water carry over. I need to sit down a figure out an elbow or something that will not allow any bubbles to get sucked up. During sheet rock dust removal it doesn't take long for the water to become mud, but, there is no dust escaping from the exhaust of the shop vac. I'll post up a better pic tomorrow that shows the water level better, maybe ill use some clean water lol.
Soapdish is offline
post #9 of 16 (permalink) Old 01-24-2010, 08:28 PM
Bob N's Avatar
First Name: Bob
hmmmm.... my wife has one of those Rainbows, I wonder if she would miss it if I took it out to the shop
Bob N is offline
post #10 of 16 (permalink) Old 01-24-2010, 08:53 PM Thread Starter
Soapdish's Avatar
First Name: Jake
Yes...she would. I used ours once on some drywall dust where I had been doing some work in a closet. Mine was not happy.
Soapdish is offline
A Little Tour of my Little Shop!.... challagan Tools and Woodworking 31 10-03-2014 12:39 PM
Repairing leaking hot water tank TRN_Diesel DIY and Renovation 43 01-15-2010 01:15 AM
Help: Hot Water System Gone Wild morgantruce DIY and Renovation 8 12-27-2009 08:40 AM
Vacuum Filter Bags Mike The Bargain Bin 9 03-20-2009 12:03 PM
