My Flooded Table saw restore - Router Forums
post #1 of 4 (permalink) Old 01-25-2010, 11:36 PM Thread Starter
Default My Flooded Table saw restore
I recently restored a delta 34-338 table saw that ended up in the Nehalem river flood Dec. 2008 (What a mess) but all went well and I plan to upgrade my table saw into a cabinet system with my router at the end of the table. I have seen several plans only to become more unsure what would be best for my shop. My shop is 20' x 24' with a Drill press, chop saw and bench, Work bench, band saw, grinder, belt sander and all my wife's holiday crap as well (don't tell her I said that) what I think I need is a good plan for about a 6" cabinet with a lift system. Any advice for a space limited wood guy would be helpful.......Thanks
Jeff Ransom is offline
post #2 of 4 (permalink) Old 01-26-2010, 12:20 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Hello Jeff, and welcome to the RouterForums. Thanks for joining.
Dave
the "Doctor"
Dr.Zook is offline
post #3 of 4 (permalink) Old 01-26-2010, 03:41 AM
xplorx4's Avatar
First Name: Jerry
Greetings Jeff and welcome to the router forum. Thank you for joining us.
Lamentations 3:22-23
xplorx4 is offline
post #4 of 4 (permalink) Old 01-26-2010, 08:53 AM
dutchman 46's Avatar
First Name: Howard
Wink
Hello, Jeff! Glad to have you join us. Another thing you could do is to set your router into the table such as the guys of Router Forum. The router just sets in place, and you can lift it out with the router plate, and adjust the height before you set it back in. No cost for a lift, and no special set up to worry about. Then later, if you want to upgrade, you can still add a lift. Not all lifts work the same. and if you see one down the road that just has to come home home with you, it can be done then. And i won't tell your Wife about any thing!!
John 3:16
dutchman 46 is offline
Help with router and table djonesax Table-mounted Routing 31 08-27-2012 06:10 PM
Looking for input on home built router table italian biker Table-mounted Routing 10 07-24-2009 09:49 AM
Novice router question RonH General Routing 10 02-02-2009 09:07 PM
Router Table Help Which One! bigroccrek Table-mounted Routing 25 04-08-2008 10:57 PM
