Left Tilt / Right Tilt - Router Forums
post #1 of 2 (permalink) Old 02-04-2010, 10:51 AM Thread Starter
fibertech's Avatar
First Name: Derek
Send a message via AIM to fibertech
Default Left Tilt / Right Tilt
I have been away from the forums for several months and know this subject has been discussed. I live about 25 miles from Grizzly in Bellingham and want to buy a Contractor's Table Saw. Their catalogue only shows Left Tilt saws. Can someone share an opinion before I write to them? I have purchased many items from Grizzly and their support is great. Thanks -Derek
fibertech is offline
post #2 of 2 (permalink) Old 02-04-2010, 11:18 AM
With a left tilt you would not have to move the fence to the other side of the blade for a safer operation. You can use the right side measurement & table length for support of wider pieces as in normal use. You do not want to trap your material between the blade & the fence. The only place for the material to go is right back at you. The material gets pinched between the blade, fence, & tabletop. You want to tilt the blade away from the fence for a safer miter cut. Most table saws have more table to the right of the blade which allows wider cuts.
Whittier, CA.
Have a nice & safe day!
jlord is offline
Beall Tilt Box Versus Wixey Angle Gauge bennybbc Tool Reviews 4 02-04-2010 12:01 PM
Bosch Colt - tilt base setting wm_crash General Routing 1 01-30-2010 09:48 AM
Tilt Table Robin Special Needs Woodworking 53 03-23-2009 01:12 AM
Left Hand Tools Froix Shop Safety 15 01-22-2009 06:34 AM
Left tilt vs Right tilt tabel saws Lt. Ball Tools and Woodworking 1 03-26-2005 03:27 PM
