plans for wood x-y table and rotary head - Router Forums
post #1 of 4 (permalink) Old 02-11-2010, 08:46 PM Thread Starter
First Name: MIKE
Default plans for wood x-y table and rotary head
anyone have plans for a wood x-y table and rotary head to use on a drill press?
mikered86monte is offline
post #2 of 4 (permalink) Old 02-12-2010, 01:25 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums Mike. Thanks for joining.
Dave
the "Doctor"
Dr.Zook is offline
post #3 of 4 (permalink) Old 02-12-2010, 02:08 AM
MarcoBernardini's Avatar
Country: Italy
First Name: Marco
Send a message via MSN to MarcoBernardini
I made a small X Y table, but with iron because I can't find wood robust enough to assure a decent precision. Sorry, I don't have drawings... I'll take some photos, anyway.
Basically it is made with a 2 mm iron sheet.
the Y axis movement is obtained with two L shaped bars welded below the sheet, sliding on the sides of the drill table.
The X axis moves on a sort of T rails created just stacking two layers of flat bars over the sheet. Inside these rails there are sliding flats, same thickness of the central layer, with recessed bolts for a small drill press vise.
I made it because my drill press don't have a lot of clearance, and a commercial X Y vise would reduce the available space too much (apart to be more expensive than the drill itself).
X and Y axes are surely not perpendicular, but for what I'm doing now it is better than a plain vise bolted to the table.
A rotary table is in my thoughts: I think to bolt a bearing inside a thick piece of MDF to the central hole of the table, adding some rails to have a sort of vise working as a 4 jaws lathe chuck.
MarcoBernardini is offline
post #4 of 4 (permalink) Old 02-12-2010, 05:32 AM
xplorx4's Avatar
First Name: Jerry
Greetings and welcome to the router forum. Thank you for joining us.
Lamentations 3:22-23
xplorx4 is offline
diy wooden X-Y table and rotary head SparkyOR Jigs and Fixtures 28 02-10-2012 10:10 AM
