diy bandsaw riser - Router Forums
post #1 of 15 (permalink) Old 02-13-2010, 07:09 PM Thread Starter
Default diy bandsaw riser
I recently bought a bandsaw and before i start investing in blades I would like to make/buy a riser. This bandsaw looks very much like mine.
Mine is about 15 years old.
I was thinking of using an alluminum I beam or steel/aluminum tubing, or a steel/aluminum bar and weld a plate of steel to it. Then drill the holes in the steel.
snowluck is offline
post #2 of 15 (permalink) Old 02-13-2010, 07:18 PM
Hamlin's Avatar
First Name: Ken
If I'm seeing your pics correctly, a simple "block" may work. Of course, this would depend on "how much do you intend on adding in height?" Aluminum would be your best material of choice though.
Ken
"A VETERAN"
Hamlin is offline
post #3 of 15 (permalink) Old 02-13-2010, 07:38 PM Thread Starter
i want to expand it about 6" or so to make it use a 105" blade. That is a photo of a similar bandsaw, my camera isn't working right now. Also, How would I measure how much i need to add to make it use a 105" blade
snowluck is offline
post #4 of 15 (permalink) Old 02-13-2010, 08:05 PM
Example: Jet 14" bandsaw use a 93-1/2" blade. Add a 6" riser & the blade length extends to 105". So I think adding a 6" riser to your band saw will make use of a 105" blade.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #5 of 15 (permalink) Old 02-13-2010, 08:11 PM
AxlMyk's Avatar
After you add a riser block, you need to add a longer guide post. That will set you back a bit to have made.
AxlMyk is offline
post #6 of 15 (permalink) Old 02-13-2010, 08:23 PM
Hi snowluck
Your in luck, that looks like Grizzy/HF band saw
H7316 Riser Block For G0580
post #7 of 15 (permalink) Old 02-13-2010, 08:26 PM Thread Starter
could i just use my standard guide post, they are longer than needed. Is their anyway i could make a guidepost myself, i have access to my schools shop, if it is needed?
snowluck is offline
post #8 of 15 (permalink) Old 02-13-2010, 08:28 PM
Take a look at it & see if it is something you can handle. Anythings possible.
Whittier, CA.
jlord is offline
post #9 of 15 (permalink) Old 02-13-2010, 08:39 PM
Hi
You could by why reinvent the wheel
post #10 of 15 (permalink) Old 02-13-2010, 09:00 PM Thread Starter
the main reason would be price, but i might get the grizzly one once i check the pattern for my bandsaw and compare it to the pattern for the riser
snowluck is offline
Finally Found Another Bandsaw RustyW Tools and Woodworking 6 07-27-2009 06:06 AM
Looking at buying a bandsaw... frootloops Tools and Woodworking 5 06-22-2009 09:47 AM
Grizzly GO636X 17" Ultimate Bandsaw GoonMan Tool Reviews 1 07-27-2008 02:22 AM
Bandsaw box affliction. NewMontanaWorkshop Show N' Tell 25 04-10-2007 04:59 PM
Bandsaw advice needed Bob N Tools and Woodworking 7 06-07-2005 03:15 PM
