Table Saw Restoration - Router Forums
post #1 of 30 (permalink) Old 02-19-2010, 05:44 PM Thread Starter
Soapdish's Avatar
First Name: Jake
Default Table Saw Restoration
I picked up this Delta table saw (model 34-670) off CraigsList last weekend. The seller said the motor didnít work. $47 and it followed me home. The top had a nice coating of rust, but didnít seem to be pitted. The extention wings are stamped steel, but in good shape and not bent. The fence is in decent condition, just needs some cleaning up. After getting the saw home I quickly found that the motor for this saw was ok, just the timing belt was worn down. I found a supplier on Ebay and by mid week I had a new one on the motor. I started on the top first thing using Naval Jelly to get the majority of the rust off. After that I used a ROS with a scotch brite pad and mineral oil to start getting any of the rust stains out. Finished it off with 220 grit on the ROS and then 400 and 600 by hand. I then removed the trunnion and disaseembled everything. The lead screws were rusty, but cleaned up quicly using a wire wheel and 400 grit. The fence guide was beat up pretty good, but a couple hrs of work and it looks good as new. Today I finally got the saw back together and tuned the saw up. The blade was easy to get parallel to the miter slots and then I set the 90 and 45 adjustments. I ripped some test boards today and man this thing cuts nice. The motor as expected is loud, but with the thin kerf blade Iíve got on there rips right through with no troubles. This weekend Iíll finish cleaning up the wings (hopefully I can find some paint that will match up ok), and get the fence rails back on. Hereís some pictures for you viewing enjoyment, looks like they are a little out of order, sorry.
My favorite thread on routerforums.com. Great Posts
Soapdish is offline
post #2 of 30 (permalink) Old 02-19-2010, 07:45 PM
CanuckGal's Avatar
First Name: Deb
Jake you did an awesome cleanup job on that table!!! What a great deal! Congrats!
I measured, I marked, I cut.
CanuckGal is offline
post #3 of 30 (permalink) Old 02-19-2010, 08:52 PM
TwoSkies57's Avatar
jake, great job of the table...the old gal will continue to turn out projects for years to come ...
or ya could trade her in for a lil dental work..*S*..
TwoSkies57 is offline
post #4 of 30 (permalink) Old 02-19-2010, 09:01 PM Thread Starter
Soapdish's Avatar
First Name: Jake
LOL...that dude looks rough huh!
Soapdish is offline
post #5 of 30 (permalink) Old 02-19-2010, 09:23 PM
First Name: Daryl
47 bucks?!!! I'll give you fifty. No kiddin'. Right now.
sofasurfer is offline
post #6 of 30 (permalink) Old 02-19-2010, 09:23 PM
TwoSkies57's Avatar
A minute after I hit the "Post" button, I thought,,ahhhhhh man,what if that pic is the real deal...
all I can say is *WHEWWWWWWW*!!!!!!!!!!
post #7 of 30 (permalink) Old 02-19-2010, 10:25 PM Thread Starter
Soapdish's Avatar
First Name: Jake
Nah, that ain't me...but it makes people say..man that dude is messed up! LOL
Soapdish is offline
post #8 of 30 (permalink) Old 02-19-2010, 11:08 PM
drasbell's Avatar
Hey I had that same saw for years I bought it new in a Lowe's and used it for like 13 years or so then I recently bought a grizzly saw and sold the delta for 150.00 with a spare motor, its a great saw.. nice job by the way... it shoud serve you well.
Life: Is a runaway train you cant wait to get on.
drasbell is offline
post #9 of 30 (permalink) Old 02-20-2010, 12:21 AM Thread Starter
Soapdish's Avatar
First Name: Jake
Thanks Rick, it's good to hear first hand knowledge of this saw. While trying to find a replacement belt I found that a lot of people hated how loud this saw is, so I was a little concerned. After running it today I can agree that it is very loud, but what else would expect from a gear drive running at 5500 rpms? I wanted a solid saw that I could make improvements on and this will serve that purpose. I've been using a cheap pro-tech saw for years, so this saw is like a Caddy to me. You said you sold your old one with a spare motor, did the original die on you? (i've read that is common with these motors)
Soapdish is offline
post #10 of 30 (permalink) Old 02-20-2010, 05:53 AM
allthunbs's Avatar
First Name: Ron
Hi Jake:
Beautiful job. Keep you gearbox clean and well lubricated and it should give you many years of good service.
What are you going to name it? After all that work, it has to have a name.
Allthunbs
allthunbs is offline
Help with router and table djonesax Table-mounted Routing 31 08-27-2012 06:10 PM
Looking for input on home built router table italian biker Table-mounted Routing 10 07-24-2009 09:49 AM
Novice router question RonH General Routing 10 02-02-2009 09:07 PM
Router Table Help Which One! bigroccrek Table-mounted Routing 25 04-08-2008 10:57 PM
