Random Orbit Sander - Router Forums
post #1 of 9 (permalink) Old 02-22-2010, 10:49 AM Thread Starter
jjmill1980's Avatar
First Name: Jeremiah
Default Random Orbit Sander
A few questions about RO Sanders
  1. Where is the cheapest place to buy/order hook & loop sanding discs?
  2. What is the best/cheapest way to replace the hook & loop backing pad?
  3. How long should the hook & loop backing pad last?
  4. If using the universal hole (fits 5 hole, 8 hole, ...) sanding discs, does the extra junk that gets between the H&L backing pad and the sanding disc wear out the H&L faster?
I ask this question because I am on my 3rd RO sander in about 7 years. My first was a Bosch, 2nd Ryobi, and 3rd Ridgid. I use this tool a lot but even then it does not see daily use. I don't know how many times I replaced the backing pad & H&L pad on the Ryobi. I have had the Ridgid for about 6 months now and the H&L is starting to go.
jjmill1980 is offline
post #2 of 9 (permalink) Old 02-24-2010, 11:14 AM Thread Starter
jjmill1980's Avatar
Does no one out there use a RO sander???
post #3 of 9 (permalink) Old 02-24-2010, 11:49 AM
First Name: George
I use Home Depot and Klingspor. And yes I do have a RO sander...two to be exact..
George
"Regulae Stultis Sunt"
George II is offline
post #4 of 9 (permalink) Old 02-24-2010, 12:29 PM
First Name: Warren
Yeah, use 'em all the time. I am using a Milwaukee this morning. And I have a couple Makita's andI think an old Craftsman. I don't seem to have the same problems you do. And I've worn out a backing pad.
Might I be so bold as to ask......do you really LEAN on your sander when using?
You may also have bad Karma....and there's nuttin we can help you with there. Maybe cook a skunk in a rubber pot over a buffalo chip fire and dance around a bit but thats all.
sourdough is offline
post #5 of 9 (permalink) Old 02-24-2010, 12:36 PM
Hi
I have many and I got mind from Grizzly they have the sand paper also.
post #6 of 9 (permalink) Old 02-24-2010, 10:20 PM
BigJimAK's Avatar
I've had an old (12-15 years old) DeWalt... Only recently got another after the plastic on the dust catcher cracked. I got the second one to test the new-style dust catcher vac adapter with the old one. I haven't checked (or used) it yet but if it works I figured I'd just get a new-style adapter for it too. It doesn't hurt to have a second ROS. Has anyone ever tried two-fisted ROS sanding? I've heard of two-fisted drinking, but...
BigJimAK is offline
post #7 of 9 (permalink) Old 02-25-2010, 12:27 AM
Talking
Hi - Welcome to the forum
This is the best I can do:
1 - Wal-Mart
2 - Dunno, haven't had one wear out yet.
3 - Refer to #2.
4 - Refer to #3
John Schaben
jschaben is offline
post #8 of 9 (permalink) Old 03-06-2010, 08:20 AM
First Name: Don
It has been my observation that some of the cheap papers don't last as long as some of the more pricey papers, so if changing out your paper at a 2-1 ratio I don't see any cost savings. Do yourself a favor and compare a cheap pack to a more costly choice and discover the longer life.
winm70 is offline
post #9 of 9 (permalink) Old 03-06-2010, 12:31 PM
Country: Iceland
First Name: galturner
I believe heat is the culprit..go lightly and keep the paper as cool as possible
gal turner is offline
Sander question reikimaster Tools and Woodworking 11 07-14-2011 03:23 PM
Random Orbital Sander vs Power Planer ebeard Tools and Woodworking 17 01-24-2011 09:33 PM
which random orbit sander should I buy lovoy7381 Starting Off 19 09-29-2009 07:45 PM
Bosch 3107 DVS 5" Random Orbital Sander rstermer Tool Reviews 5 06-15-2009 09:56 PM
My Sander Arrived!... challagan Tools and Woodworking 9 04-26-2007 09:50 PM
