Picture frame suggestions - Router Forums
post #1 of 3 (permalink) Old 02-24-2010, 10:22 AM Thread Starter
First Name: Warren
Smile Picture frame suggestions
I KNOW some of you folks have made picture frames at one time or another and I seek your wisdom.
Want to make some simple frames to go in a little winter retreat. I have a new miter saw (from Harbor Freight and I will do a report on this thing) and all the tools etc. but I suspect there are little "tricks" that wise old woodworkers know.
Will you share?
Thanks.
Your old pal, formerly Birch, but now compelled to be Sourdough. Which I actually am!!
sourdough is offline
post #2 of 3 (permalink) Old 02-25-2010, 10:53 AM
Trimax's Avatar
First Name: Curt
to get really tight corners 1st make sure your at a true 45deg and 2nd the blade is as true to 90 deg as you can get it.
Trimax is offline
post #3 of 3 (permalink) Old 02-25-2010, 02:09 PM
MarcoBernardini's Avatar
Country: Italy
First Name: Marco
Send a message via MSN to MarcoBernardini
Some years ago, before to buy a miter saw, to avoid the 45 problem I made a frame with raised squares in the corners... but it was for a cubist painting
MarcoBernardini is offline
Picture frame router bit ryansdad323 Table-mounted Routing 7 01-31-2010 08:17 PM
picture frame techniques reds_21 Tools and Woodworking 15 06-30-2009 04:43 PM
How should I trim picture frame splines? lrr General Routing 4 02-11-2007 09:59 PM
Fold-Out picture frame help edbd1100 Tools and Woodworking 17 06-30-2006 09:52 PM
Picture frame molding reible General Routing 4 11-14-2004 07:22 PM
