Panels: Spaceballs being compressed on assembly? - Router Forums
post #1 of 5 (permalink) Old 02-26-2010, 11:18 AM Thread Starter
dawziecat's Avatar
First Name: Terry
Default Panels: Spaceballs being compressed on assembly?
Panel "barrels" actually. 1/4" wide. I am assembling and gluing panels is an unheated basement in winter. Temperature about 8C(47F). RH is unknown . . . probably high but actual water vapour content is low even at high RH in such temperatures compared to summer.
The "barrels" take up 1/4" of the panel slot. I try to cut the panels so as not to compress the barrels. My thinking is that the panels are pretty much as small as they ever will be at such temperatures and will only get larger at room temperature and summer humidity.
But the accuracy required in sizing the panels is at the edge of my woodworking accuracy. Most of the time I end up with a slightly oversize panel, compressing the rubber barrels slightly. On one panel, I ended up with it too small and could create a gap by wiggling it side-to-side. I didn't like that at all.
How do you guys handle this with spaceballs, panalign strips or barrels?
Compress slightly on assembly or what?
Terry Danks
Rural Nova Scotia(or Florida)
Nature and Wildlife Photography
http://danks.netfirms.com/home.htm
dawziecat is offline
post #2 of 5 (permalink) Old 02-26-2010, 11:30 AM
Hi Terry
They are needed with solid panel doors,the wood is always on the move and without them the panel can crack the frame.
Not to say any thing about a door that makes noise when you open and close it. it's best to cut the panel short by 1/16" or a 1/8" on all 4 sides..
post #3 of 5 (permalink) Old 02-26-2010, 11:37 AM
Hi Terry
Bob - by "all 4 sides" are you saying overall width and length are reduced by 1/8 to 1/4"?
John Schaben
jschaben is offline
post #4 of 5 (permalink) Old 02-26-2010, 02:06 PM
tdublyou's Avatar
First Name: Tim
Terry,
I would agree with Bob on the sizing and, you're right, those panels are probably as small as they will ever be.
Tim
tdublyou is offline
post #5 of 5 (permalink) Old 02-26-2010, 03:28 PM
Hi John
Yes all 4 sides, some woods move more than others,pine is a big mover most get it almost green with big knots from the big Orange Box Stores
Most bits cut 7/16" deep..so to say 1/8" to 1/4" is not a big deal.
Is there quick fix for slightly loose fitting raised panels? tpyke General Routing 4 06-16-2010 07:12 PM
finishing raised panels Padawan Learner Tools and Woodworking 9 11-11-2009 03:36 PM
Router for raised panels Jtomwoods Table-mounted Routing 5 11-03-2009 07:20 PM
Squaring plywood panels ShaneB Table-mounted Routing 46 10-14-2009 05:28 PM
Raised Panels Quick and Easy bobj3 Jigs and Fixtures 2 06-03-2006 12:56 PM
