Bolts vs. screws - Router Forums
post #1 of 11 (permalink) Old 03-02-2010, 12:22 AM Thread Starter
Kallen's Avatar
First Name: Keith
Default Bolts vs. screws
This is my first furniture piece, and I need some advice.
I am building for my daughter a desk/loft bed. I am using primarily 2x4 and 2x6 lumber. The legs will be 2x6 as is the mattress box. I am using lap joints for a nice look. However, this is where I am second guessing. The box that the mattress will be laid in is 2x6 with a plywood bottom. Since 2" thick lumbar actually measure 1 1/2" , using a lap joint makes the individual boards a rather thin 3/4". I had thought to use carriage bolt (1) on each corner through this joint (the mattress box is rather heavy as-is, without mattress and kid). The problem I see is that at only 3/4" thick I can't countersink the nut and retain any real strength in the wood. The nut obviously can't be INSIDE the box as it would be against the mattress. i had also planned on a couple wood screws (screwed from the inside) just to give the corners added strength.
I guess I am wondering if I am really underestimating the strength of woodscrews? meaning, could I use just 3 or 4 wood screws (per joint) and have sufficient strength?
Kallen is offline
post #2 of 11 (permalink) Old 03-02-2010, 01:00 AM
Hi Keith
Nice thing about lap joints is they look good and are very strong. I think I would use bolts though. Use t-nuts on the inside and countersink the bolt heads and flat washers on the outside. You can hide the bolts with plugs if you want.
John Schaben
jschaben is offline
post #3 of 11 (permalink) Old 03-02-2010, 08:21 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Hi Keith, I really can't argue with John's advice.
Harry
harrysin is offline
post #4 of 11 (permalink) Old 03-02-2010, 09:15 AM
Cochese's Avatar
First Name: C
I was always taught that you wanted screws for the ability to resist coming apart, nails for shear, and bolts for both.
My two cents, I'd go bolts.
Cochese is offline
post #5 of 11 (permalink) Old 03-02-2010, 09:22 AM
Hi Keith
The make bolts just for that type of job, don't forget you may want to take it down in time plus they are clean and smooth and you can use a Allen wrench to put them in..
Connector Bolts
Connector Bolts - Rockler Woodworking Tools
http://www.rockler.com/product.cfm?page=367
post #6 of 11 (permalink) Old 03-02-2010, 10:48 AM Thread Starter
Kallen's Avatar
First Name: Keith
Hey BJ, I didn't even consider the bolts like that! The first link "Connector Bolts" are perfect! Don't need to be counter sunk and still looks nice too. I like the antique brass finish. Thanks for the advice everyone!!
Kallen is offline
post #7 of 11 (permalink) Old 03-02-2010, 11:13 AM
First Name: Bob
Hi Keith
Connector Bolts
Cross Dowels - Rockler Woodworking Tools
Absotively!
pretty darned handy for jigs and such too... don't leave the store without them...
anotherBob is offline
post #8 of 11 (permalink) Old 03-02-2010, 11:33 AM
BrianS's Avatar
First Name: Brian
Keith, just in case you don't have a Rockler close by, the BORG sells similar bolts and fasteners.
Brian
(Origin uncertain)
BrianS is offline
post #9 of 11 (permalink) Old 03-02-2010, 11:52 AM Thread Starter
Kallen's Avatar
First Name: Keith
Resistance is futile... I'm sold. Planned on stopping at one tomorrow and getting some! Think these would be strong enough (one per joint) or should I strengthen with screws as well?
Kallen is offline
post #10 of 11 (permalink) Old 03-04-2010, 01:48 PM Thread Starter
Kallen's Avatar
First Name: Keith
Not to bump my own thread, but I'd appreciate any opinions on the one bolt per corner question.... Do you think one per corner would be enough? Or maybe should I also add a couple wood screws as well? Thanks
Kallen is offline
craftsman router table screws reds_21 Table-mounted Routing 8 12-21-2012 07:00 PM
Torx and not so Torx screws sourdough Tools and Woodworking 2 02-01-2010 03:48 AM
Screws won't fit Router Plate don1 General Routing 24 02-16-2009 05:29 PM
plate screws rout1111 Table-mounted Routing 1 10-02-2008 08:03 PM
