Heard of "Ram Tools"?? - Router Forums
post #1 of 12 (permalink) Old 03-05-2010, 07:21 PM Thread Starter
Kallen's Avatar
First Name: Keith
Default Heard of "Ram Tools"??
OK, so a couple weeks ago I picked up a circular saw pretty cheap, used. It's a Ram Tool R725. I can NOT find any info on this. There is nothing on Google at all. I am trying to put a new blade on it. I got the old one off, but when I try to tighten the bolt the motor turns, so I can't get it tight. There is no motor lock, so I don't know what to do..... Anyone have a CLUE on this?? Thanks!!
Kallen is offline
post #2 of 12 (permalink) Old 03-05-2010, 07:46 PM
Knothead47's Avatar
Try Chattanooga, TN at 423-698-0653 or 423-698-0835. If this is the same bunch, Ram sells to industrial and construction markets. Good luck!
Knothead47 is offline
post #3 of 12 (permalink) Old 03-05-2010, 08:30 PM Thread Starter
Kallen's Avatar
First Name: Keith
I should have clarified...Since there's no motor lock, I sat the saw on my vice and tightened it on the blade, this way I could take off the old blade. But when I tighten the bolt, I can hold the blade but the when I turn the bolt the motor is moving.
Thanks for that info John. The info on the label says Chicago, IL, but the info i found on the numbers you gave sound like a good lead.
Kallen is offline
post #4 of 12 (permalink) Old 03-06-2010, 07:58 AM
DerekO's Avatar
First Name: Derek
Normally I use a 2x4 to have the blade bite into when I am tightening up mine. Or loosening it for that matter.
I have never seen one with a blade or spindle lock, just the one wrench that goes into the two holes. But I have also only really seen 3 circular saws close up in my life too.
DerekO is offline
post #5 of 12 (permalink) Old 03-06-2010, 09:06 AM Thread Starter
Kallen's Avatar
First Name: Keith
One wrench into two holes? This model doesn't have any holes, just the nut... There is no way to prevent the motor from turning with the nut hat I can find.
Kallen is offline
post #6 of 12 (permalink) Old 03-06-2010, 09:22 AM
Easy and safe way to replace the blade on the power hand saw ..
post #7 of 12 (permalink) Old 03-06-2010, 09:28 AM
Knothead47's Avatar
Kallen, Chicago would more than likely be corporate offices, if this is the same bunch. I found the numbers in the business section in my local phone book. Depending where you live, there might be a local listing under "Ram Tools."
post #8 of 12 (permalink) Old 03-06-2010, 09:30 AM
Knothead47's Avatar
Try 1-888-RAM-TOOL.
post #9 of 12 (permalink) Old 03-06-2010, 11:57 AM Thread Starter
Kallen's Avatar
First Name: Keith
Thanks for all the suggestions....the problem has been solved (thanks to my dad). His circular saw has a raised washer that puts pressure on the blade, so regardless of blade thickness there's no issue. However, MY saw has a flat washer, and as it turns out the blade I bought was the tinniest bit thinner than the original blade...thin enough that the flat washer wasn't putting enough pressure on the blade, allowing the slippage. Comparing the blade I got to some of my dad's revealed the difference, and putting on a thicker blade made all the difference...
Kallen is offline
post #10 of 12 (permalink) Old 03-06-2010, 04:15 PM
DerekO's Avatar
First Name: Derek
Glad you got it figured out.
The 2 holes in mine are on either side of the nut piece (more than just the nut) that goes around the spindle/arbor. I watched my father-in-law change the blade on it and he used the same method I use.
DerekO is offline
Anyone heard of or used Ginkgo? RStaron Wood Species 7 12-16-2009 04:52 AM
any one heard of router called alfy part timer Starting Off 3 05-27-2009 02:43 AM
Has anyone ever heard of a Martin Moto-Cut Tool? NDGary Lobby 3 07-01-2008 11:44 PM
