Oversize guide bushings? - Router Forums
post #1 of 4 (permalink) Old 03-09-2010, 02:29 AM Thread Starter
BigJimAK's Avatar
Default Oversize guide bushings?
Is anyone aware of oversize (OD > 1-1/2") guide bushings, whether for the PC mount, OP mount, or a specialized plate, such as a Milescraft? I'm looking for offset using a 1/2" bit, so an ID of 5/8" or more is good.
BigJimAK is offline
post #2 of 4 (permalink) Old 03-09-2010, 07:25 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I'm not sure what it is that you're after Jim because you haven't stated the off-set that you're attempting to achieve. As you well know, in order to calculate the off-set, we need to know the cutter diameter AND the OD of the template guide, we can then use the formula: OD of guide minus dia. of cutter divided by two.
For critical offsets where even a mixture of Imperial and metric guides/cutters doesn't help, I sleeve guides as shown in this shot, I also do it to achieve a critical diameter of bearing.
Harry
harrysin is offline
post #3 of 4 (permalink) Old 03-09-2010, 08:48 AM
Hi Jim
You lost me too, you can make a off set ring any size you want it to be...
post #4 of 4 (permalink) Old 03-09-2010, 09:31 PM Thread Starter
BigJimAK's Avatar
Harry... I don't have a need right now. When I was installing the pin router arm in my table top I could have used some though, so I was just looking for choices for the future.
BJ... You're right, and with the Jasper's ability to cut from 1"D to 7"D by 1/16ths, making my own would be a breeze.. Cancel my question. I'll just make them as I need them.
BigJimAK is offline
Using guide bushings with your router Mike Guide Bushings and Templates 15 12-04-2013 12:32 PM
matching Bosch router to PD guide bushings. drtimdc Guide Bushings and Templates 5 01-03-2010 06:18 AM
Help! Rockler Std. Guide Bushings? Richard44 General Routing 3 06-20-2009 01:12 PM
routers levon Table-mounted Routing 18 10-03-2008 09:11 PM
need something to use guide bushings on! Help Please!! unlimitedwoodworker Guide Bushings and Templates 8 11-15-2007 03:42 PM
