Powr-Kraft Radial Arm Saw - Router Forums
post #1 of 4 (permalink) Old 03-09-2010, 07:26 AM Thread Starter
First Name: rob
Default Powr-Kraft Radial Arm Saw
Came across this unit at an auction, and although I have some typical tools like your average table saw, miter saw, router etc. , I had never seen one of these before.
It was made around 1964, has a 2hp motor and has 2 auxillary spindles on opposite end of blade, one runs at 10,000 rpm the other at 3,450. It came with the original owners book and the drill chuck and grinding stone.
I had no way to know if it worked, but when the starting bid dropped from $100 all the way down to $10, I thought I had to find out. Got it for $10 and it does run. I cleaned it up and squared the blade in all direction. Now I just need to make a top and fence.
Was hoping to find some support about making the top, and see if anyone has any further knowledge of this unit. I can't locate any parts or attachments anywhere. Any help would be greatly appreciated.
Thanks,
Bob
shanny is offline
post #2 of 4 (permalink) Old 03-09-2010, 11:09 PM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Hi Rob
Welcome to the forum. There seems to be quite a lot of information at Powr-Kraft Radial Arm Saw - by dustynewt | LumberJocks.com :: woodworking community Whilst the earlier posts are a couple of years old, there are recent ones at the bottom.
HTH
Peter
istracpsboss is offline
post #3 of 4 (permalink) Old 03-09-2010, 11:35 PM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums Rob. Nice to have ya here.
Dave
the "Doctor"
Dr.Zook is offline
post #4 of 4 (permalink) Old 03-14-2010, 03:03 PM
dutchman 46's Avatar
First Name: Howard
Hello, rob, Welcome to the router forums I have not seen anything like it before. You have a very good find. You will find something on the tool sites, if not from here, I must say, I really like the set of lites that came on it!!!!Ha, could it be a special use type saw?
John 3:16
dutchman 46 is offline
Radial Arm Saws. Still used? CanuckBeaver Tools and Woodworking 35 03-14-2010 05:56 PM
Radial Arm Router cabinetman Tools and Woodworking 12 04-27-2007 10:22 PM
radial arm saw KENNETH KIDWELL Lobby 2 05-09-2006 09:10 PM
