Multi-Sided Glue Joint clamps - Router Forums
post #1 of 5 (permalink) Old 03-12-2010, 03:57 PM Thread Starter
First Name: Dominik
Default Multi-Sided Glue Joint clamps
Hi.
I have this set
I need easy to make claps for Multi-Sided boxes.
I make simple clamps using wedge and belt but it take many time to joint all elements.
tigerhellmaker is offline
post #2 of 5 (permalink) Old 03-12-2010, 04:11 PM
Hi
Just use some wider rubber bands,works great..also surgical tubing work well also.. just tie in into a knot ,I use 1/8" most of the time
Originally Posted by tigerhellmaker View Post
Hi.
I have this set
post #3 of 5 (permalink) Old 03-12-2010, 07:58 PM
First Name: Bob
First choice - Scotch 233+ tape - this stuff is fantastic!
Good second choice - Jet 15' Strap Clamp - pretty handy for alot of things too...
anotherBob is offline
post #4 of 5 (permalink) Old 03-12-2010, 08:04 PM
If you want to go high tech, the clamps below work great I have 4 of them for the real hard jobs
Merle Clamp with self adjusting jaws
post #5 of 5 (permalink) Old 03-12-2010, 09:45 PM
First Name: Drew
Depends how strong it needs to be and what glue you're using.
If it needs to be strong and you're using PVA you want a strap clamp.
If not or you're using epoxy tape or rubber bands are sufficient.
I have a couple of the Bessey clamps that I like -
Amazon.com: Bessey VAS23 Vario Angle Strap Clamp: Home Improvement
Drew Eckhardt is offline
Glue Joint GerhardWessels Table-mounted Routing 8 12-20-2009 02:10 AM
Glue joint vrs Tongue & Grove DougA Router Bits - Types and Usage 2 05-19-2009 10:35 AM
Biscuit or glue joint Ghidrah Router Bits - Types and Usage 13 11-13-2008 04:10 PM
glue joint router bit aurgathor Router Bits - Types and Usage 12 12-05-2007 12:24 PM
