variable speed not staying - Router Forums
post #1 of 4 (permalink) Old 03-13-2010, 09:07 PM Thread Starter
First Name: Steve
Default variable speed not staying
I run a Ryobi RE600. When I dial the speed I want and start to work the speed gets slower. The machine doesn't seem to stay where I put it. What should I be looking for as far as repairing it?
SteveD
srdu7993 is offline
post #2 of 4 (permalink) Old 03-14-2010, 12:38 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums Steve. Glad to have you as a member.
Dave
the "Doctor"
Dr.Zook is offline
post #3 of 4 (permalink) Old 03-14-2010, 01:21 AM
Variable speed and constant speed are two different things. Routers like the Bosch and other top line machines have the constant speed circuitry that applies more power as the load on the bit increases and that helps to stabilize the rpm though even that is not perfect and you can feel the router slow somewhat under havier loads.
I think you need to find out if your router has the constant speed feature and if it does, contact Ryobi about their authorized service centers if need be.
Tom Hintz, Publisher
NewWoodworker.com
Tom Hintz is offline
post #4 of 4 (permalink) Old 03-14-2010, 01:34 PM
Ghidrah's Avatar
First Name: Ronald
I have the 694VS kit comes with the case.
The 690vs router has a dial.
One thing I noticed right off the bat the 1st time I used it was that if I pressed the motor, (moving too fast or hard wood or both) the rpms dropped automatically and stayed at that speed even after pulling away.
I've had 2 690s since around 03, 1st died from composite decking both did this, rpm drop when pressed. It freaked me out when it happened the 1st time, I never questioned the shop I bought it from and don't recall ever finding anything writtein about it
Ghidrah is offline
Variable Speed vs. Fixed Speed Phillip K General Routing 26 10-23-2013 10:38 AM
Bypassing Craftsman variable speed control emptyjay General Routing 13 02-14-2011 04:10 PM
Router Bit Sizes And Variable Speed Settings mack. Router Bits - Types and Usage 4 02-18-2010 11:33 PM
Variable speed routers MichaelT General Routing 10 02-24-2009 12:46 PM
rule of thumb for variable speed? rprice54 General Routing 3 01-11-2006 05:50 PM
