Sanforno - Router Forums
post #1 of 4 (permalink) Old 03-27-2010, 09:19 AM Thread Starter
Default Sanforno
Is a 2 1/4 hp router big enough for raised panel doors ?
sanforno is offline
post #2 of 4 (permalink) Old 03-27-2010, 09:37 AM
Hi
Yes, just my 2 cents,,the big panel bits are made to cut the panel in one pass but most take more than one pass the norm, so it's the same by using a 2 1/4 HP router,I will say making 3 cuts works the best, in that way if you have any burn marks the last pass will remove them...
You can get the big panel bits that come with 2 bearings, (small one and a big one) just for that job.
post #3 of 4 (permalink) Old 03-27-2010, 10:30 AM
Gene Howe's Avatar
First Name: Gene
Hi
A 2.25 hp will certainly do the job. Wood species will dictate the # of passes.
My raised panel bits are all CMT with the set of 2 bearings. After using the bearings (which do a fine job) I found it simpler and quicker to adjust the fence for each cut.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #4 of 4 (permalink) Old 03-27-2010, 11:01 AM
Hi Gene
How do you make your arched raised panel doors ?
With just the fence adjustment ..the sommerfeld way with a 1/2 fence ?
sanforno sanforno New Member Introductions 2 03-27-2010 02:36 PM
