Jointer table out of whack - Router Forums
post #1 of 3 (permalink) Old 03-28-2010, 12:39 AM Thread Starter
First Name: Andy
Default Jointer table out of whack
Gentlemen,
I work in a cooperative woodshop and recently someone shoved the 8"jointer around and now the infeed and outfeed tables are not level. The infeed table tilts up about 3/64ths of an inch at the beginning edge, sloping down to the blades. I am fairly proficient with the jointer and when I continued to get a more and more acutely curved edge after each pass I realized something must be wrong.
Does anyone have any suggestions on how one might fix this problem without sending the machine back to Delta. It is probably about 20 years old now and any kind of trick or a precisely placed shim to fix it would be a great help. I might just take the whole thing apart and see if I can do something to get it close to true.
Thanks,
Andy
PS I have gone through the manuals(nothing in there about the tops being out of alignment), but have yet to call the Delta Help line.
Carpenterman is offline
post #2 of 3 (permalink) Old 03-28-2010, 01:33 AM
Shims are usually needed to correct table positioning on jointers though there have been models (parallelogram) that have corner adjustments on each table. i expect you would have found that in the manual though if it was that advanced.
If it went out just from being moved I would go over all of the play adjustment screws (grubb) along the keyways on that table to be sure nothing had loosened up. It usually takes significant force to get a table that far out of alignment on a dovetail keyway jointer.
Tom Hintz, Publisher
NewWoodworker.com
Tom Hintz is offline
post #3 of 3 (permalink) Old 04-06-2010, 11:32 PM Thread Starter
First Name: Andy
Thanks Tom,
That is a start. I am going to call Delta as well as take the thing apart and put it back together. Hopefully I can find a solution to the problem.
Andy
Help with router and table djonesax Table-mounted Routing 31 08-27-2012 06:10 PM
Router Table Completed - Finally! Rutabagared Show N' Tell 12 08-01-2011 09:22 AM
For Sale: RS 500 Router Table - routertabledepot.com sheridan Woodworking Classifieds 1 08-20-2009 09:51 AM
New router, need table, building dovetail cabinets santana157 General Routing 7 02-02-2009 11:34 PM
