steel plate wings? - Router Forums
post #1 of 1 (permalink) Old 04-01-2010, 11:08 AM Thread Starter
Default steel plate wings?
Ok, so i just purchased a used early 80's craftsman 10 inch table saw and I already want to improve it. I am limited on money an want to do the most I can with the least money. I want to replace the stamped steel 10" wings with something stiffer and flatter. I don't think I will be able to afford the cast wings for some time but have some steel around that I can make a frame and use steel plate for the top. Is this a common alternative? I realize I will have to be carefull on the welding so that I do not warp the wing. I have also seen wood or formica topped pannels used as wings.
So what are the cons of using steel plate and steel flat bar for ribs to make wings. What are the cons of formica covered wood.
Thanks,
John
flybyjohn is offline
Router Plate Installation Rutabagared Project Plans and How To 11 01-14-2012 07:15 PM
MLCS/Harbor freight router plate inserts not flush with plate Mike Gager Table-mounted Routing 14 12-22-2009 09:54 PM
Building first table-- need advise on router plate gbuy2001 Table-mounted Routing 9 11-04-2009 05:42 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 01:08 PM
