Need ideas on what do or convert my old benchtop table saw to - Router Forums
post #1 of 13 (permalink) Old 04-01-2010, 07:54 PM Thread Starter
DerekO's Avatar
First Name: Derek
Default Need ideas on what do or convert my old benchtop table saw to
I need ideas on what do or convert my old benchtop table saw to.
I have been thinking I don't want to sell it as it doesn't have the blade guard or anti-kick back pawls anymore.
So does any one have any ideas on what to do with it? generic sized cheap 10" benchtop table saw with stand. Does have a dust collection port that fits vacuum hose if I recall correctly.
Or should I just sell it?
DerekO is offline
post #2 of 13 (permalink) Old 04-01-2010, 08:25 PM
kp91's Avatar
First Name: Doug
sell it, download the manual from OWWM.com, let the buyer know that he/she will need to get a guard for it.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 13 (permalink) Old 04-01-2010, 09:15 PM
BigJimAK's Avatar
Derek...
If you can get a good price, certainly sell it but otherwise you could make it into a dedicated 10" disc sander for about $35. With the dado slot etc., it'd be pretty sweet. They sell them to "convert your TS back and forth" but I've heard many voice concerns that it'll cause wear on the TS bearings, leading to a small amount of blade wobble. For a dedicated sander though, who cares? Others who have tried these will likely join in. I have not.
Here's a link... also on Amazon...
Sanding Supplies - Table Saw Calibration and Sanding Disc
Oops.. just noticed it's now on sale.. $29.99 with 6 free discs.
Just a thought...
BigJimAK is offline
post #4 of 13 (permalink) Old 04-01-2010, 09:55 PM Thread Starter
DerekO's Avatar
First Name: Derek
Doug, I have copies of the manual...looks like 2 original manuals but one must have been printed or copied when my Wife used to have access to this super copier/printer set up. There isn't a way to get a guard for it unless some how the person is able to figure out which saws are clones of it. I tried in last December to get the parts and the web site is now a parked domain. The original safety equipment was dangerous anyways. The saw was bought some time between 1994 and 2000....neither one of us can remember. Never got used until 2003.
Jim, that is what I have been thinking of the most. I haven't had need of a sander like that yet, but can see the need for it in the future. That on sale now just might tip the Mrs towards that way about it.
If I do sell it, it will have to be buyer beware, no safety equipment included right at the top of the ad. I suppose some one could add an aftermarket splitter to it as those are very cheap, just a couple of bucks, or even make one out of some thin hardboard or other material that is right around 1/8". And an overarm blade guard could be made out of plexiglass or polycarbonate or something of that sort.
DerekO is offline
post #5 of 13 (permalink) Old 04-01-2010, 10:51 PM
BigJimAK's Avatar
Harry S has a 10 or larger.. hopefully he will join in...
BigJimAK is offline
post #6 of 13 (permalink) Old 04-02-2010, 08:29 PM
RStaron's Avatar
First Name: Ron
I'd go the disc sander route myself. I use the one on my Shopsmith alot. Haven't had any problems with it wearing out bearings either. You can make jigs to sand round discs and do many things with it. You might be surprised at how much you can do with it.
A person can never have too many tools!
RStaron is offline
post #7 of 13 (permalink) Old 04-03-2010, 12:08 AM
BigJimAK's Avatar
Default HarrySin
I know I've seen Harry do some wonderful things with his... It looked like he was using coarse discs and almost "melting" away the waste.
BigJimAK is offline
post #8 of 13 (permalink) Old 04-03-2010, 06:11 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
I think that you're referring to my linisher (belt/disc sander) Jim it has a 6" belt and 9" disk and is a tool that I can't imagine living without. I have several different grit belts but can't remember using anything other than 80grit, as you suggested, it's possible to press a length of hardwood against the disk and watch it vanish! Rubber sticks are available to unclog the discs, but a piece of white poly reticulation pipe works just as well.
As for Derek's dilemma, I reckon that I'd have a go at converting it to a drum sander, about 6" wide and diameter determined by how close to the bench the spindle can rise. I'm not sure how easy or difficult it would be to make the cut-out using a jig saw with a suitable metal cutting blade, or possibly with an angle grinder, but where there's a will there's a way, isn't there Jim.
Harry
harrysin is offline
post #9 of 13 (permalink) Old 04-03-2010, 09:50 AM Thread Starter
DerekO's Avatar
First Name: Derek
I have a good friend who owns a welding shop. So if it needs cutting, I can get it done.
Also have a father-in-law who did 30 some years as an Iron Worker.
All I need is to know what to tell them to do. I do have an angle grinder, but only used it for a little bit of cutting and used to use the roto-zip's zipmate wheel to do that stuff instead, but nothing up to what these guys can do.
DerekO is offline
post #10 of 13 (permalink) Old 04-03-2010, 10:24 AM
harrysin's Avatar
First Name: Harry
Go to it Derek, amaze us all!
Harry
harrysin is offline
Two routers, or "router-saw-router" table? charleyb Table-mounted Routing 17 04-16-2012 09:27 PM
First and only (I hope!) Router table CanuckBeaver Table-mounted Routing 14 10-04-2010 05:12 AM
Current iteration of Sommerfeld router table Doc Jackson Table-mounted Routing 44 07-26-2010 09:33 AM
Sold: Router Table or Table Top -Sam- Woodworking Classifieds 10 01-29-2005 09:15 PM
