Help needed - Router Forums
post #1 of 31 (permalink) Old 04-22-2010, 06:02 PM Thread Starter
mcdonelldj's Avatar
First Name: Dave
Default Help needed
I am building a rolling tool cabinet that I found on Woodsmith.
I have just about everything cut when I realized the plan calls for 1/2" wood for the drawers. I had not bought the wood yet so I went to the store for the wood and discovered that the white board I was going to use doesn't come in 1/2".
I do not have a thickness planer.
The other two options that I can think of are to use 1/2" plywood or 1/2" in MDF. The drawers have tongue and groove joints so there are no box or dovetails.
Which of these would be preferable or is there a third option that does not involve spending $269 on that Porter Cable thickness planer I've had my eye on.
Thanks in advance,
Dave
mcdonelldj is offline
post #2 of 31 (permalink) Old 04-22-2010, 06:11 PM
allthunbs's Avatar
First Name: Ron
Thanks in advance,
Dave
That's easy! Are you married?????
Allthunbs
allthunbs is offline
post #3 of 31 (permalink) Old 04-22-2010, 06:20 PM Thread Starter
mcdonelldj's Avatar
First Name: Dave
Yep
post #4 of 31 (permalink) Old 04-22-2010, 06:48 PM
Thanks in advance,
Dave
Hi Dave, look like an opportunity to justify the thickness planer but if it's the budget and not the wife, my choice would be the plywood. I'm not sure about the durability of MDF for shop drawer boxes. I used it for drawer fronts but not the boxes.
John Schaben
jschaben is offline
post #5 of 31 (permalink) Old 04-22-2010, 07:21 PM
First Name: Robert
I would go with the ply, also. I have used 1/2" MDF for drawer bottoms, but they were small drawers. I think you'll find that 1/2" ply is a little thinner than 1/2", but it'll work.
alderman is offline
post #6 of 31 (permalink) Old 04-22-2010, 07:49 PM Thread Starter
mcdonelldj's Avatar
First Name: Dave
You guys are awesome! Thanks! I have some 1/2" ply in garage so I'm in luck.
I haven't ruled out a planer for later
post #7 of 31 (permalink) Old 04-22-2010, 07:50 PM
kp91's Avatar
First Name: Doug
The plywood will work well, but you might want to consider using pocket hole joinery instead of the T & G.
Lowes does sell 1/2 inch pine boards in their craftwood section, but it's not that cheap, about $1.25 for a 1/2 x 3 x 24 inch piece.
A long shot is to see if there is a local WW club nearby where someone would share his planer for a small fee. I see ads for that sort of thing in the North Virginia Craigslist from time to time.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #8 of 31 (permalink) Old 04-22-2010, 07:52 PM
Hi Dave
Next time you get to Denver stop by Paxton Lumber they have 1/2" thick lumber in the racks, in all types..I should say it's a candy store for the wood worker, don't take your card with you the last time I was in the store they had a Roll Top Desk kit all pre cut Oak stock parts plus all the hardware in brass..
Frank Paxton Lumber Company
Google Maps
Thanks in advance,
Dave
post #9 of 31 (permalink) Old 04-22-2010, 08:06 PM
AxlMyk's Avatar
I don't think I've ever heard of drawers made with pocket hole stuff. Sometimes I think PH is overrated.
Tongue and groove, dovetails, or locking rabbets is what I would use.
AxlMyk is offline
post #10 of 31 (permalink) Old 04-22-2010, 09:42 PM Thread Starter
mcdonelldj's Avatar
First Name: Dave
I made a set of drawers with the 1/2" plywood I had on hand. For this tool box it will work fine but if I ever make an actual piece of furniture I think I will go for the 1/2" lumber. The plywood is okay but it tends to chip out a little cutting the dado grooves.
bobj3, I work in Denver occasionally and I will definitely stop by when I get a chance. That store looks nice!!! I usually get my wood from Lowes since there is one less than a mile from my house.
Thanks for all the suggestions. I may actually get this project finished this weekend.
why is centering cone needed? sofasurfer General Routing 9 02-01-2010 11:50 AM
Router selection help needed robdunstan Table-mounted Routing 19 02-14-2008 03:37 PM
Drawers I needed mit-ch Woodturning and Lathes 9 02-08-2008 08:35 AM
Help needed simonedwards Lobby 4 08-02-2005 08:19 PM
