Jasper 400 Circle Guide - Router Forums
post #1 of 10 (permalink) Old 05-25-2010, 12:53 PM Thread Starter
Default Jasper 400 Circle Guide
I'm thinking of picking up a 400, primarily for making offset rings. It also looks to be a good tool for making bushing ready base plates. While circle guides are relatively easy to make in the shop, the $20 price tag doesn't seem worth the effort to try to duplicate the capabilities.
I'm pretty sure it will fit my Hitachi M12VC, does anyone know if it will bolt up to a Freud 1700? Any suggestions/input would be appreciated.
John Schaben
jschaben is offline
post #2 of 10 (permalink) Old 05-25-2010, 01:57 PM
Hi John
You don't need to bolt it up to your router just drill out the center hole to 3/4" ID and just use a brass guide, in that way it will fit just about any router you have..
I will say it's best not to bolt it up ,they have a small down fall with the Jasper jig ,the mounting holes breaking out very easy, see the reviews on Amazon..
post #3 of 10 (permalink) Old 05-25-2010, 04:20 PM Thread Starter
Hi John
Hi Bob - Thanks for the input. Just may be the show-stopper though as the main reason I'm wanting it is to make offset rings. 3/4" hole would wipe out the 1" capability from the looks of it. I was also thinking it could be used to make base plates to take the large guides
John Schaben
jschaben is offline
post #4 of 10 (permalink) Old 05-25-2010, 05:50 PM
Hi John
That's true, I have made my share off sets rings and base plates and it's best to use Forstner Bits for that job,, the center hole must be dead on plus the pocket hole for the guide must be dead on... for the PC type and the OakPark type plus it's best to make base plates square not round pie is sq.not base plates
But I'm sure you can use the Jasper 400 to make them but I think it will be a hit or miss thing most of the time..sq.ones are so easy to make draw a X and drill the holes out on the center of the X mark.
Off set rings, once you have the center hole drill out drop it on a dowel pin (1" or 1 1/2" with a 1/8" pin hole in the center for the Jasper ) stick it to a scrap stock and use the Jasper to cut the rings out..
post #5 of 10 (permalink) Old 05-25-2010, 09:18 PM Thread Starter
Hi John
Hi Bob - I was thinking I would be doing them the other way. Put the 1/8" hole in and use the Jasper to cut the OD and, whenever possible, use the 1" guide cut off the same hole. Resort to the drill press if I needed to use a smaller bushing.
As far as the base plates go, I was thinking of doing the bolt pattern first and with the blank subbase attached, plunge the 1/8" guide hole for the Jasper. I don't mind square, they easy
John Schaben
jschaben is offline
post #6 of 10 (permalink) Old 05-26-2010, 10:36 AM
Hi John
That will work But I will say using the holes saws work the best for making off set rings (magic donut)...you can get a set or two from HF at the right price that will do the job.. if I recall each set for about 8.oo bucks that should cover all the sizes you will want to make.. they are not hvy. duty but they will do the job quick and easy...
Search results for: 'hole saw'
post #7 of 10 (permalink) Old 05-26-2010, 02:25 PM Thread Starter
Hi John
Hi Bob, Yeah, I picked up the $10 one (18 piece) awhile back. I think part of my reluctance about the drill press is that it's a HD Ryobi special. Don't have a good way to check runout so I don't know where that's at. Setting depth is kind of a crap shoot also.... doesn't give me a warm fuzzy about the accuracy of the thing.
I'm guessing that the Jasper is acrylic, not polycarbonate, which would explain failures of the mounting holes from overtorquing. I think I'll probably go ahead and get the Jasper. Just be careful torquing it down.
John Schaben
jschaben is offline
post #8 of 10 (permalink) Old 05-26-2010, 03:25 PM
Hamlin's Avatar
First Name: Ken
Hi John,
Not meaning to dissuade from the Jasper but, you might want to take a look at this one.
http://www.sears.com/shc/s/p_10153_1...scraft&prdNo=3
Ken
"A VETERAN"
Hamlin is offline
post #9 of 10 (permalink) Old 05-26-2010, 05:43 PM Thread Starter
Originally Posted by Hamlin View Post
Hi John,
Hi Ken, thanks for the link. Problem is that I want to use it for offset rings which means I will need diameters in the 1-3" range. Jasper 400 is the only one I've run across that meets that requirement.
I've thought about hole saws but they are spec'd to the OD, plug cutters are spec'd to the ID (also expensive), Forstner is also spec'd to the OD and I don't think circle cutters are quite precise enough.....at least not without a bunch of tedious setup. Guess that's where I'm at right now, looking at it like a tool to make more tools.
John Schaben
jschaben is offline
post #10 of 10 (permalink) Old 05-26-2010, 07:18 PM
Hi John
Here's a little trick I use to make off set rings, clamp the stock to the drill press table top. drill the 1" or 1 1/2" hole with the Forstner bit than chuck up the hole saw ,(without unclamping the stock) you want the OD to be and cut out the ring...very easy and very quick..
Need help with jasper circle jig 200 melissa973 Jigs and Fixtures 13 10-19-2011 06:26 PM
Circle Jig - Jasper 400 BigJimAK Tool Reviews 23 03-12-2010 07:51 AM
Router template inlay V Garry General Routing 7 12-27-2008 06:49 PM
Jasper Circle jigs for Router cassiusclay Jigs and Fixtures 5 05-21-2007 07:40 PM
