Odds of this fixing the Mitre Saw wobble - Router Forums
post #1 of 4 (permalink) Old 05-30-2010, 10:15 PM Thread Starter
Marco's Avatar
Default Odds of this fixing the Mitre Saw wobble
Hi all and hope you are enjoying your Memorial Day weekend!
While cutting some wedges out of a 2x8, I had a chunk of wood get stuck in the saw blades teeth........ yeah a big bang with a sudden stop! The end result is a wobble in the blade at a low RPM. The wobble straightens out at a high RPM. Hoping for a cheap fix, I replaced the blade with a brand new one.... the wobble is still there.
Attached is a link to a diagram of the Motor Assembly http://www.searspartsdirect.com/part...0028632&blt=06. The first part is the cutter shaft assembly #2BX4. Do you believe that if the cutter shaft assembly is replaced that the saw won't have a wobble? I need your advice because I don't want to be stuck with a part I don't need. If I need to replace the Armature Assembly which is the 4th part #2AKT, I'll be putting that money towards a new Mitre Saw as its price is over half the cost of the saw.
Thanks in advance
Galatians 5:13
Marco is offline
post #2 of 4 (permalink) Old 05-30-2010, 10:50 PM
Hi Marco
I would suggest you drop it off at one of the many server centers and let them check it out for you, they have the equipment to do that right..you don't need them to repair it for you but they can tell you for sure what part needs to be replace.. and then go from that point..sale it on CL stating it has a wobble in the blade ,some don't care if they use it for construction jobs..
Thanks in advance
post #3 of 4 (permalink) Old 05-31-2010, 05:01 AM
Hamlin's Avatar
First Name: Ken
I agree with Bj, take it in, left them look at it. If by chance that you decide to make the repair yourself. Providing you end up replacing the shaft, replace the bearings as well. You're there, no point having them go out on you within a next few uses. Doubtful you'll need to replace the armature assembly. Look at this way, money well spent on preventive maintenance.
Ken
"A VETERAN"
Hamlin is offline
post #4 of 4 (permalink) Old 05-31-2010, 07:47 AM Thread Starter
Marco's Avatar
Thank you Bob and Ken
Galatians 5:13
Marco is offline
Mitre Gauge Size pucknutt51 Table-mounted Routing 10 04-12-2009 01:23 PM
Mitre groove salty Table-mounted Routing 2 12-02-2008 07:17 PM
Do you use a mitre gauge on a table? neoshed Table-mounted Routing 10 11-01-2007 08:32 PM
Locking mitre joints for picture frames grandsire02 Table-mounted Routing 3 08-10-2007 01:56 AM
Home made mitre fence? normcatalunya Jigs and Fixtures 9 11-01-2005 02:51 AM
