Bandsaw Riser Block - Router Forums
post #1 of 11 (permalink) Old 06-20-2010, 04:17 PM Thread Starter
Default Bandsaw Riser Block
I have a Rockwell Model 14 Bandsaw and I want to get a riser block for it so i can cut larger bowl blanks and start cutting veneers. I don't know which riser block to get. I measured the rod that holds the guide for the blade and its a cylinder, slightly less than 1" in diameter, like .98". It has a flat section which is .45" across and it is .9 in diamter at the flat segment. This might help in determining what riser to get.
snowluck is offline
post #2 of 11 (permalink) Old 06-20-2010, 04:34 PM
levon's Avatar
First Name: levon
im not familiar with that saw, if it is an older saw, it may be difficult.
you really need the riser that is built for your saw. the riser kit also comes with a front and rear blade guard and a guide post and a replacement bolt.
you really need to replace all of the parts.
i just did a lot of research for my bandsaw. i havent added the riser kit yet, but did add a kreg fence, which is the best thing ive done to my saw.
after just reviewing your other posts, you may find some other that may fit. according to BobJ the grizzly may fit. his opinions are usually exactly right. now watch me get a message from him "usually right?"
levon
levon is offline
post #3 of 11 (permalink) Old 06-20-2010, 11:39 PM Thread Starter
The saw is about 15 years old, i'm not sure what that classifies it as.
snowluck is offline
post #4 of 11 (permalink) Old 06-21-2010, 06:27 AM
AxlMyk's Avatar
I'm thinking a Delta kit would fit it.
Post a couple pics.
AxlMyk is offline
post #5 of 11 (permalink) Old 06-21-2010, 07:35 AM
First Name: del
order the delta riser block It will come with all you need for the conversion The blade will be 105" I have have the block on mine for about 15 yrs Works great
del schisler
port st. lucie, florida
del schisler is offline
post #6 of 11 (permalink) Old 06-21-2010, 11:42 AM
BigJimAK's Avatar
"The blade will be 105""
I added a riser kit to mine last year. What's obvious but what I didn't think about at first was that you'll need all new blades. It's a good time to budget for a really good blade or two. I went with a TimberWolf, but there are others available too.
BigJimAK is offline
post #7 of 11 (permalink) Old 06-21-2010, 09:10 PM Thread Starter
the delta riser block is a little expensive compared to the other riser blocks, like, about double the price
snowluck is offline
post #8 of 11 (permalink) Old 06-21-2010, 09:40 PM Thread Starter
i just found ariser block on ebay, a delta block
cgi.ebay.com/Delta-Band-Saw-Riser-Block-/230490502451?cmd=ViewItem&pt=LH_DefaultDomain_0&ha sh=item35aa4df533#ht_500wt_896
which is currently at 8 dollars
it only includes the block, so how much work would it be to make the blade guard assembly and the guide post?
to make the guide post could i get another peice of metal bar the same diameter as my current one, weld it to the current one, and then grind a flat spot the same size as the original bar with an angle grinder? I'm going into 10th grade, which is when we switch from middle school to highschool in my district, and i'm not taking shop next year and i don't know the shop teacher there, so i nolonger have access to the shop.
snowluck is offline
post #9 of 11 (permalink) Old 06-21-2010, 10:42 PM
Hi
Just pickup one from Grizzy and you have all you need ..
Grizzly.comŽ -- Search Results
http://www.grizzly.com/products/Rise...or-G0580/H7316
http://cgi.ebay.com/Delta-Band-Saw-R...3#ht_500wt_896
quote=snowluck;191805]i just found ariser block on ebay, a delta block
to make the guide post could i get another peice of metal bar the same diameter as my current one, weld it to the current one, and then grind a flat spot the same size as the original bar with an angle grinder? I'm going into 10th grade, which is when we switch from middle school to highschool in my district, and i'm not taking shop next year and i don't know the shop teacher there, so i nolonger have access to the shop.[/quote]
post #10 of 11 (permalink) Old 06-24-2010, 09:57 AM Thread Starter
I think i'll get a grizzly, but which one? I looked over my bandsaw and found the demensions near the post area are 3.3" by 4.65"
It also say 112D, which i guess is a serial or something.
And then in another area near it, it says:
126-06
089-2002
but the slashes look like division symbols
snowluck is offline
Deluxe Push Block bobj3 Jigs and Fixtures 111 12-25-2012 08:29 AM
diy bandsaw riser snowluck Tools and Woodworking 14 02-15-2010 11:49 AM
Finally Found Another Bandsaw RustyW Tools and Woodworking 6 07-27-2009 06:06 AM
Riser Blocks RustyW Tools and Woodworking 4 02-16-2009 11:22 AM
Grizzly GO636X 17" Ultimate Bandsaw GoonMan Tool Reviews 1 07-27-2008 02:22 AM
