Wood stain - Router Forums
post #1 of 7 (permalink) Old 06-29-2010, 07:29 PM Thread Starter
3efingers's Avatar
Default Wood stain
My daughter has asked me to build her a keepsake box and the color that she wants is best described as "real dark cherry". I was thinking of using cherry wood and mahogany stain.
Any thoughts or ideas.
I got lost in thought. it was unfamiliar territory.
3efingers is offline
post #2 of 7 (permalink) Old 06-29-2010, 09:19 PM
AxlMyk's Avatar
Cherry wood and cherry stain. You can take much of the liquid out of the can before stirring it up. That will leave more of the pigment to make it darker.
Leaving cherry in the sun will also darken it.
AxlMyk is offline
post #3 of 7 (permalink) Old 06-29-2010, 10:13 PM
First Name: Dean
First reply nailed it; putting cherry stain on cherry just kind of makes it darker. Direct sunlight does the same thing, although that'd take a couple months to work.
talldean is offline
post #4 of 7 (permalink) Old 06-29-2010, 11:24 PM
crquack's Avatar
Here is a cherry wood with red mahogany (gel) stain finished with spray-on poly (left) and wipe-on poly (right), both with a steel-wool-and-wax last coat. Note the left piece was a trial piece and the top is not planed.
You make the call...
crquack is offline
post #5 of 7 (permalink) Old 06-30-2010, 06:08 PM Thread Starter
3efingers's Avatar
Thanks guys, I'll try the AxlMyk method first, be the end of August before I can get started but soon as I can I'll post some photos.
post #6 of 7 (permalink) Old 07-20-2010, 05:11 AM
First Name: Derek
looking forward to your photos.
it looks interesting.
Dereklee is offline
post #7 of 7 (permalink) Old 09-04-2010, 07:54 AM
First Name: Jerry
I let the sun darken it. I then linseed oil it to pop the grain, apply a 1lb cut of shellac, very lightly sand it and apply my choice of top coat.
Bonka is offline
Introduction to Wood Species... BobandRick Wood Species 40 03-19-2015 12:03 PM
Framing a small piece of wood lea6141 Table-mounted Routing 10 08-19-2010 04:01 PM
Failed stain crquack The Finishing Touch 1 06-28-2010 01:52 PM
wipe on stain clear coat more stain (layers) tiggol The Finishing Touch 6 03-22-2010 10:35 AM
A Wood Experience-Contest Woodworkers Source Contests Archive 2 05-14-2009 05:58 PM
