Ideas: router milling jig for brass and bronze - Router Forums
post #1 of 4 (permalink) Old 07-05-2010, 08:50 PM Thread Starter
First Name: Bob
Default Ideas: router milling jig for brass and bronze
Hey all,
Anyone used their router for milling brass and/or bronze? I can get my parts pretty close size/shape-wise with my bandsaw and belt grinder. Would like to build a "simple" jig for machining the last bit... exactly. Ideas/pictures...?
anotherBob is offline
post #2 of 4 (permalink) Old 07-05-2010, 11:45 PM
crquack's Avatar
I see the issue as that of speeds: The maximum speed for peripheral miling of brass is AFAIK 350 sfm. You can increase it by 35% if you use Titanium Carbonitride coated end-mills. This would give you about 15,000 rpm for a 1/8" end-mill. Most routers go down to 8,000 rpm, so this is about the largest end-mill one could use and even then it is being pushed to the max.
For me, I do not see the practicality of such approach.
crquack is offline
post #3 of 4 (permalink) Old 07-06-2010, 07:47 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Originally Posted by anotherBob View Post
Hey all,
I personally wouldn't even consider such a project, a multi-speed drill press lends itself to various ingenious modifications much simpler to those done to one of my drill presses by it's previous owner.
Harry
harrysin is offline
post #4 of 4 (permalink) Old 07-06-2010, 08:07 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Even that is tricky, as the bearings in drill presses are not designed/intended for lateral pressure.
I definitely would not use a router. CRQ expressed it perfectly. Don't do it !
Cheers
Peter
istracpsboss is offline
