I'm thinking of buying a used Porter Cable Sander Model 343VS... what do you think? - Router Forums
post #1 of 16 (permalink) Old 07-09-2010, 12:50 PM Thread Starter
First Name: Guido
Default I'm thinking of buying a used Porter Cable Sander Model 343VS... what do you think?
Currently I only have a 1/4 sheet palm sander that doesn't work too well on the larger jobs. What do you think on the item below, and is there anything I should inspect (it's used)?
Thanks,
Guido
Porter Cable - Sander - Model 343VS - 5" Variable Speed Random Orbit sander w/case - $40
Gweedz is offline
post #2 of 16 (permalink) Old 07-09-2010, 05:55 PM
BigJimAK's Avatar
ROS's are definitely my go-to tools. I started with a pad and then a belt sander but once I got my ROS, the others rarely get used.
I say that.. I used the 4x24 belt sander with 18 grit to "plane" some pieces of hard maple trim mostly into level, but still finished up with the ROS.
I'm no expert on inspecting used... I know most ROS companies sell replacement pads (replace from the mounting bolt down) which will let you convert between PSA and H&L but I don't know how to tell if one is worn out. Hopefully one more knowledgeable than I on this will jump in!
BigJimAK is offline
post #3 of 16 (permalink) Old 07-09-2010, 07:28 PM
Hi Guys
" one is worn out " a good test is free run the tool with out any load on it,, it should not run ruff or smell bad at the free run and no sparks from the motor brushes ,the next easy test ,run it under a hvy,load and mean under hvy.load with your weight on it, it should run like the free run test but with a load and it should come out of the test run and run free and smooth when you drop the power to it..if not ,say no thank you and keep looking..
post #4 of 16 (permalink) Old 07-12-2010, 08:46 AM Thread Starter
First Name: Guido
Thanks guys. I picked it up on Saturday and it passed all tests. It's in excellent condition and the guy said he used it maybe twice. It does look like new. However, I did notice an "R" stamped/melted on the plastic which I believe means re-manufactured. I'm not too worried because if Porter Cable did the inspection/repair then it should be as good as new.
Now I'm looking for a deal on 5" discs...
Thanks again!
Guido
Gweedz is offline
post #5 of 16 (permalink) Old 07-12-2010, 03:39 PM Thread Starter
First Name: Guido
I bought the sander, but it looks like I may have jumped the gun.
I just found out from work that I can get an endless supply of 6" PSA discs, yet my sander is 5" hook & loop.
I'll see if I can install a 6" pad.
Oh well.
Gweedz is offline
post #6 of 16 (permalink) Old 07-12-2010, 04:56 PM
Hi Gweedz
The 6" will works just fine,you can always use a pair of Scissors free is free..
Oh well.
post #7 of 16 (permalink) Old 07-12-2010, 07:00 PM
Gene Howe's Avatar
First Name: Gene
Hi Gweedz
My kinda guy!
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #8 of 16 (permalink) Old 08-05-2010, 09:51 PM
First Name: Derek
well, a friend of mine bought it, and said it was not too bad...
a nice site about nice power drill
gardening
woodworking
Dereklee is offline
post #9 of 16 (permalink) Old 08-05-2010, 10:24 PM
You should be happy with the sander Guido. There is a simple jig you can build for putting the holes in sand paper that uses adhesive to hold it to the sander. I think with the hook and loop system you might be better off buying the pads or cutting them down to fit if they will line up.
post #10 of 16 (permalink) Old 08-05-2010, 11:30 PM
Oh well.
Musta missed this post earlier Guido - Here's where I get most of my discs:
Heleta (formerly Bullet Industries) abrasive products hook & loop discs
They been out of the 150 gtit for awhile but the rest is pretty good for the money.
You might want to check out their router bits while you're there. Been pretty good to me.
John Schaben
jschaben is offline
Porter Cable Router model 155 clyde78 General Routing 3 01-25-2012 09:19 PM
Wanted: Want a Porter Cable Router Model 155 4 amp clyde78 Woodworking Classifieds 1 08-18-2011 10:09 PM
Porter Cable Model 4212 Hammer702 Table-mounted Routing 3 04-04-2010 10:51 PM
For Sale: Porter Cable Machine Co Guild model 1101 Router Tim Young Woodworking Classifieds 0 01-30-2010 06:10 PM
Porter cable 632 vs Sander Glenmore Tools and Woodworking 6 12-10-2004 05:51 PM
