Extension cord + power strip: advice needed - Router Forums
post #1 of 16 (permalink) Old 07-15-2010, 10:56 AM Thread Starter
First Name: Mischa
Default Extension cord + power strip: advice needed
Y'all - I'd like to use a 10-gauge extension cord for running two (or more) tools (at least router/jigsaw/sander/drill + vacuum). I am looking for a solid power strip to go with the extension cord. Any recommendations?
I can find lots of power strips with cables, but they seem to be thinner than 10-gauge (if I can find that info at all). I don't want to run a 10-gauge extension cord, just to have it limited again by the cord in the power strip.
Thanks! MM
xvimbi is offline
post #2 of 16 (permalink) Old 07-15-2010, 11:20 AM
Hi Mischa
I don't think you will find one most of the power strip are rated at 15 amp. max but that's not a big deal you can make your own by bolting two 4 gang boxes together along with a overload breaker and your 10 gag.wire.
The breaker you can get from most elec.store warehouse outlets ,the push button reset type (20 to 30 amp.) that fits right into a 4 gang box.
Thanks! MM
post #3 of 16 (permalink) Old 07-15-2010, 11:38 AM
Cochese's Avatar
First Name: C
What about something like this?
Link
The 144 Workshop - Ambitious but rubbish woodworking
Cochese is offline
post #4 of 16 (permalink) Old 07-15-2010, 11:45 AM Thread Starter
First Name: Mischa
Thanks y'all!
Bob: I was playing with the idea of making my own version but wanted to see first if there is anything suitable on the market.
Chris: If that came in a mountable strip version it would be ideal. Maybe one could cut out the relevant portion. Will have to take a look.
Thanks again! MM
xvimbi is offline
post #5 of 16 (permalink) Old 07-15-2010, 11:54 AM
Why not a 12g extension cord with a t-tap (3-outlet end) or a GFCI portable quad outlet cord?
http://www.lowes.com/pd_145278-33536-30334054_0_?productId=1135929&Ntt=extension+cord&N tk=i_products&pl=1&currentURL=/pl__0__s?newSearch=true$Ntt=extension%20cord$y=0$x =0
(EDIT) Don't know why link from Lowe's came out this way.
But here is another link of the extension cord like at Lowe's
http://www.conney.com/Product_Facili...75_11367_11367
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #6 of 16 (permalink) Old 07-15-2010, 12:12 PM
Why do you need 10g? Won't 12g work for you? All my extension cords are 12g & I run router with shop vac no problem. I wouldn't go smaller then 12g for shop tools. 14g tends to twist up after awhile.
Whittier, CA.
jlord is offline
post #7 of 16 (permalink) Old 07-15-2010, 12:23 PM
Cochese's Avatar
First Name: C
Thanks y'all!
Thanks again! MM
You could always mount it to the wall. The only problem would be if you stored the line on it and unwound it, the plugs would rotate.
Cochese is offline
post #8 of 16 (permalink) Old 07-15-2010, 12:26 PM Thread Starter
First Name: Mischa
I need about 25-50 ft of extension cord and was hoping to find a 10-gauge solution to be on the safe side. I could try going with 12-gauge. Thanks - MM
xvimbi is offline
post #9 of 16 (permalink) Old 07-15-2010, 12:39 PM
Cochese's Avatar
First Name: C
I've not had any issues with 12ga @ ~50ft. It's what the shop has been powered by since I got started.
I'm using this, combined with that reel:
Link
Water resistant, too.
Cochese is offline
post #10 of 16 (permalink) Old 07-15-2010, 12:41 PM Thread Starter
First Name: Mischa
Chris - Would you mind telling me what tools you can run simultaneously through your 50ft 12ga setup? I just don't have a good feel for that (yet). Thanks so much! MM
xvimbi is offline
Setting Up a Small Wood Shop?? Advice Needed? WoodHaven Tools and Woodworking 63 08-31-2017 02:45 AM
Cnc advice needed mderzio CNC Routing 5 04-09-2008 07:32 AM
Bench Dog Advice needed LonePalm Table-mounted Routing 1 01-13-2008 01:49 PM
power supply/extension cord questions rprice54 Tools and Woodworking 10 06-28-2006 04:31 PM
Bandsaw advice needed Bob N Tools and Woodworking 7 06-07-2005 03:15 PM
