Fixing the WS3000 Wide Blade Sharpener - Router Forums
post #1 of 9 (permalink) Old 07-19-2010, 12:55 AM Thread Starter
BigJimAK's Avatar
Default Fixing the WS3000 Wide Blade Sharpener
I recently picked up a WorkSharp 3000 after trying my hand at tuning some bevel-up Veritas 3/16" thick A2 steel plane blades. The instructions say to attach the wide blade guide, leveling it with the sharpening sandpaper. Unfortunately, it won't go down that far, because the inside of some of the supports squeeze against a raised piece of the machine. Sooo... I got out my Dremel and a carborundum cutting wheel and trimmed them back. I've attached a picture showing where I had to grind. It only took a couple of minutes and it was level.
Please note it was the *inside* of the support, not the "bottom".
I'd previously called WS and they told me it didn't have to be level, just co-planar, a cop-out to me. I wanted to use my Veritas honing guide with it and to use the angle setter, I needed level.
All this because some of the blades are 25*, some 38* and some 50*. It worked like a champ! I've attached a picture showing the reflection of some ribbed rubber matting in the blade. Scary sharp!
BigJimAK is offline
post #2 of 9 (permalink) Old 07-19-2010, 11:17 AM
CanuckGal's Avatar
First Name: Deb
Jim that's GREAT!! I have had the same isues with the wide blade attachment and went back to my water stones for sharpening wide blades. I am going to give your method a try. Thanks for posting this.
I measured, I marked, I cut.
CanuckGal is offline
post #3 of 9 (permalink) Old 07-19-2010, 04:16 PM
TwoSkies57's Avatar
Excellent Jim!!! I'll be reworking mine this weekend. I've been using a large flat washer for quite a while. Just kinda cheesy I know. but it worked.. Your fix is the way to go..thanks...
btw.. for WS to say that the they don't have to be level, just co-planer is iffy at best.. If using their jig it may be ok, I, like you, use a veritas jig and never bothered even trying out theirs. it may in fact work out.. i dunno.. but with a jig like the veritas or similar rig, its a big nope...no way...definately will change the angle of approach....
again, thanks, great work..
bill
Skipper the Penguin
TwoSkies57 is offline
post #4 of 9 (permalink) Old 07-19-2010, 04:36 PM
Thanks Jim
I guess I will rework my 3000 this week
post #5 of 9 (permalink) Old 07-19-2010, 08:45 PM Thread Starter
BigJimAK's Avatar
Let me know how it works for y'all.... <And "y'all" from an Alaskan!>
BigJimAK is offline
post #6 of 9 (permalink) Old 08-02-2010, 03:21 AM
First Name: Derek
yep, Jim.
youve done a good thing for all the 3000 users.
a nice site about nice power drill
gardening
woodworking
Dereklee is offline
post #7 of 9 (permalink) Old 08-02-2010, 07:49 PM
CanuckGal's Avatar
First Name: Deb
Another thing on my TODO list!
post #8 of 9 (permalink) Old 08-02-2010, 08:28 PM
TwoSkies57's Avatar
I can scratch this one off.......
good deal Jim,, thanks
beats the hell out of the big flat washer I had under the plate for the last year..*L*
Skipper the Penguin
post #9 of 9 (permalink) Old 03-14-2011, 06:35 PM
Default Just to be extra sure!
I think I understand where to grind but, in an excess of caution...
Looking at the bottom of the sharpening table you see two protrusions that look like chairs, facing each other. You do your grinding on the "front" of each chair's front leg?
Thanks!
TGYoung is offline
  LinkBacks (?)
LinkBack to this Thread: https://www.routerforums.com/tools-woodworking/22750-fixing-ws3000-wide-blade-sharpener.html
Posted By For Type Date
Sawmill Creek Woodworkers Community - Review: Worksharp 3000 + Henry Taylor Paring Chisels This thread Refback 02-06-2011 08:42 AM
Article: Review: Worksharp 3000 + Henry Taylor Paring Chisels This thread Refback 02-06-2011 04:47 AM
Article: Review: Worksharp 3000 + Henry Taylor Paring Chisels This thread Refback 02-06-2011 03:09 AM
10" blade selection?? jeep_man Tools and Woodworking 27 04-10-2009 04:57 PM
"Lo-tech" table saw blade alignment simplenik Tools and Woodworking 4 04-10-2009 12:27 PM
table saw blade selection blurry Tools and Woodworking 19 03-13-2009 12:12 PM
