resaw power - Router Forums
post #1 of 6 (permalink) Old 08-27-2010, 07:47 AM Thread Starter
Default resaw power
I have a Delta 14" bandsaw with riser block and a 1/2 HP motor. Although everything cuts, tracks etc. fine, it seems to lack the power to resaw 8" white birch boards. Would changing the pulleys to lower blade speed help? I'm pretty sure these are the original pulleys. Any other suggestions?
fishlore is offline
post #2 of 6 (permalink) Old 08-27-2010, 08:10 AM
xplorx4's Avatar
First Name: Jerry
Not enough motor,you need a minimum of 1 hp to resaw 6" or more, and most will say you need 1 1/2hp to resaw. If I ever put a riser block in my Jet 14" I think I will re-motor it yo 2hp if possiable
Lamentations 3:22-23
xplorx4 is offline
post #3 of 6 (permalink) Old 08-27-2010, 08:32 AM
First Name: del
kinda under powered. What size pulleys on motor and saw?? And is it a 1625 rpm ? What i did was put a 1" pulley on my motor and 6" pulley on saw. These are double belt and iron type , Browning mfd. Now the motor is a 3450 rpm and a 1 1/2 hp . Mine will resaw anything i run through it and no slowing down at all. The smaller pulley on the motor the more tork but also slow's down the blade.
del schisler
port st. lucie, florida
del schisler is offline
post #4 of 6 (permalink) Old 08-27-2010, 02:04 PM
BearLeeAlive's Avatar
I agree with Jerry. 2hp or more would be preferred, i 1/2hp would do the job with a slow speed. The issue with changing the gear ratio to give more torque, is that you would lose the speed (momentum) of your flywheels as well. I had a 1/2hp Delta years ago, and 1 1/2" is about the maximum that I would attempt with a hardwood, and even that was a tough go.
I have the Laguna LT14 SUV (for Souped Up Version, no kidding). It is a 3hp model, and I have resawn 13" yellow birch with no problem, getting a nice 1/8" veneer.
JIM
BearLeeAlive is offline
post #5 of 6 (permalink) Old 08-27-2010, 10:05 PM
hilltopper46's Avatar
First Name: Tony
What blade are you using to resaw? For resawing you need no more than 3 tpi, preferably on a 1/2-inch blade. More teeth that that can't pull the sawdust out of the kerf. See Suffolk Machinery Corp. - Timber Wolf Band Saw Blades and LENOX Bandsaw Blade Tooth Set Configurations
Also, slowing down the saw may help, if you are bogging down the motor.
hilltopper46 is offline
post #6 of 6 (permalink) Old 08-30-2010, 07:23 AM
Thank you all for the helpful advice. I'm going with an upgrade to 1 HP as I'm afraid my 15 amp 110 volt wiring won't permit anything more. I'll try changing pulleys if the new motor doesn't cut it (ha ha!). I don't resaw a lot so cutting speed doesn't matter to me. Thanks again for all your help.
Bill Fishlore is offline
Extension cord + power strip: advice needed xvimbi Tools and Woodworking 15 07-16-2010 10:55 AM
Power! istracpsboss Lobby 4 10-26-2008 10:14 AM
