Building a cabinet for a table saw - Router Forums
post #1 of 8 (permalink) Old 08-27-2010, 05:28 PM Thread Starter
First Name: Jason
Default Building a cabinet for a table saw
Im looking to build a cabinet for my portable table saw in order to expand its capabilities and get it a little higher (Im 6'2" with disc degeneration). Im looking for some input on the technique for constructing the cabinet itself. I want to make it approximately 6 feet long with a 1 foot table on the left side and a 3 foot table on the right (with a router table of course) and the saw between making up the other 2 feet. My idea is to build a face frame for the front and back like a kitchen cabinet either with biscuits or pocket holes to loin it. My concern is whether the frame of 1x4 will be strong enough to hold up to use of the saw. im looking for input on my plan as well as any other suggestions that might work better. thanks all
jaydubya is offline
post #2 of 8 (permalink) Old 08-27-2010, 06:08 PM
kp91's Avatar
First Name: Doug
Popular woodworking had a series called 'the little shop that could' Mark I and Mark II. The shop was centered around a benchtop saw built into a cabinet. I'll look to see if I have the link anywhere, but you might be able to find it using the search on their site.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 8 (permalink) Old 08-27-2010, 06:08 PM
Hi Jason
I have been about thinking of doing the same thing , this is what I plan on doing,see below..I get so mad because I no way to support the stock in front of the blade, I use stands now and that's not safe..I can stand in the man hole and push the stock easy from that point..
Name:	table saw top.jpg
post #4 of 8 (permalink) Old 08-27-2010, 06:35 PM Thread Starter
First Name: Jason
http://www.woodworkersworkshop.com/s...king_Plan.html
What im looking to do is something like this or very much like kp91 suggested. I need to make it rolling so I can push it off to the side when not in use. It needs to be not much deeper than the saw itself, and I will add a seperate outfeed on the back. i wish I had space to dedicate to a permanent spot but my "workshop" doubles as winter storage for my 03 cobra convertible
jaydubya is offline
post #5 of 8 (permalink) Old 08-27-2010, 07:33 PM
dutchman 46's Avatar
First Name: Howard
Those are all great ideas! I have a room problem, not a space problem. My basement has three rooms,. and each one is 10x28 feet The middle one has the heating and water, the outer rooms have the electric runs. I added an area and a door (3rd) room The door is 38x7 ft. opening, but the other room is only a 32x6&1/2 door. I am trying to figure out how to spread My tools around, and make it as painless as it can be. I love all the bases that were shown, but My rooms are too small. If You can make a tool base as shown, ans still get adequate area too move around, Go for it.
John 3:16
dutchman 46 is offline
post #6 of 8 (permalink) Old 08-27-2010, 07:51 PM Thread Starter
First Name: Jason
My plans are to only take up a 2 foot by 6 foot area when not using the saw. Unfortunately, I will only be able to use the tools from march to november. Once my car goes into the garage for the winter it cant come out until spring
jaydubya is offline
post #7 of 8 (permalink) Old 12-29-2012, 08:30 PM
First Name: Gary
thank you, Kp91, I've actually been building the Little Shop Mark II for my son in law off of the magazine (popular woodworking Sep 99) that I had in my archives. Unfortunately I've misplaced the magazine and I have to make a couple adjustments that I needed some of the measurements for. I need to warn Jaydubya, though. After I got everything cut out and started piecing it together, the drawers were NOT measured correctly and I recalled (too late) that a couple of subsequent magazines admitted they'd made several mistakes on measuring. So be careful or you'll have the "opportunity" to build several of your drawers twice!
daddygp is offline
post #8 of 8 (permalink) Old 12-30-2012, 12:25 AM
Smile
Welcome to the forum, Gary.
Sydney, Australia
jw2170 is offline
My Router Table Cabinet Is Finally Done BearLeeAlive Show N' Tell 34 01-25-2011 09:52 PM
Router table ideas Larwyn Table-mounted Routing 4 12-28-2009 01:47 AM
Router table refurb- Woodpeckers Unilift rstermer Table-mounted Routing 14 11-03-2009 12:21 PM
New router, need table, building dovetail cabinets santana157 General Routing 7 02-02-2009 11:34 PM
Fastening Router Table To Cabinet DONALD Table-mounted Routing 7 04-03-2005 11:04 AM
