Auto-ignition - Router Forums
post #1 of 11 (permalink) Old 08-28-2010, 04:19 AM Thread Starter
Country: South Africa
First Name: David
Question Auto-ignition
I was reading the back of a bottle of French Polish (see! some people really do read instructions) and it warns that the used cloths "should be disposed of safely as under some circumstances auto-ignition can occur".
Does anyone know what these "circumstances" are?
I live in South Africa which is a pretty warm place (not at the moment, it's pouring with rain). Presumably ambient temperature would be a factor.
How should they be "disposed of safely"?
David
DavidF is offline
post #2 of 11 (permalink) Old 08-28-2010, 04:26 AM
First Name: Al
Welcome to the Forum David....the reason that is written as a warning is a thing called spontaneous combustion.....(suggest you hit Wiki for the correct spelling) . If you have finished French Polishing and toss the old rag into a plastic bag, a fire can start without the presence of a flame. The heat generated by the metho and the bag is enough to cause ignition under some circumstances. Regards.....AL
Al Robins is offline
post #3 of 11 (permalink) Old 08-28-2010, 06:08 AM
First Name: Paul
The way I deal with my rags when done is to lay them flat on the concrete with a rock holding it down as long as you dont pile multiple rags on top of each other and the rag has plenty of air circulation passing over while it "drys" it should be fine I have never had one catch fire but maybe someone else will have a better solution as mine may not be correct.
Dont forget to live life for fear of death grasp each day and live it to it full otherwise it is pointless.
newwoodworker is offline
post #4 of 11 (permalink) Old 08-28-2010, 07:05 AM
First Name: Swallow
Send a message via MSN to Swallow Send a message via Yahoo to Swallow
For myself I never use rags twice and after I'm done with one it goes straight into the wood stove that heats my shop winter spring and fall which is most of the year here in Canada. During our two weeks of summer I just dump them into the fire pit outside. Replacing rags is cheap, replacing a shop, a garage or a house is NOT so I just get rid of them.
Retirement is easy, but You really have to work at it.
Swallow is offline
post #5 of 11 (permalink) Old 08-28-2010, 08:45 AM
Hi Guys
They sale a safety can just for that job, it's a 5gal. metal can with a cam loaded lid on it and you step on foot opener and the lid pop's up and you put the rags in the can, many paint shops have them...and it's a must have item in many shops,,(fire codes) if you want to see a picture of one just ask and I will post one..
here's a link to one
Amazon.com: Justrite 09100 Oily Waste Can 6 Gallon: Industrial & Scientific
post #6 of 11 (permalink) Old 08-28-2010, 09:18 AM
First Name: Jason
As a volunteer firefighter, i have actually fought a housefire that was started by stain rags thrown in a bag that spontaneously combusted
jaydubya is offline
post #7 of 11 (permalink) Old 08-28-2010, 06:17 PM
kp91's Avatar
First Name: Doug
linseed oil is not not allowed on our US flag vessels because of the auto ignition hazzard. Ultrafine steel wool too.
It's amazing what can start fires.
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #8 of 11 (permalink) Old 08-29-2010, 07:43 PM
First Name: Warren
Default BLO and steel wool deadly combo!
KP91 is dead on right. I have had linseed oil and fine steel wool burst into flame on two occasions!! I am a very careful dude with that stuff now!!
One time I was actually buffing BLO into a project with 0000 steel wool and it flamed up in my hand! Yikes!
sourdough is offline
post #9 of 11 (permalink) Old 08-30-2010, 07:25 AM Thread Starter
First Name: David
That's scary !! Unlike Swallow we have 2 weeks of winter and the rest is summer.
Steel wool surely cannot spontaneously combust if it's lying on a shelf, can it? I've got a large wad of 0000 steel wool on the same shelf as all of my thinners, french polish, paints and varnish.
Was KP91's autoignition caused by friction?
I don't even have a fire extinguisher!!
DavidF is offline
post #10 of 11 (permalink) Old 08-30-2010, 09:02 AM
woodnerd's Avatar
First Name: Cliff
Any type of finish that "cures" generates heat while curing. When you take finish-soaked rags and pile them together in a tight area, the heat can reach the flash point and ignite.
Lay them out on a board outside the shop. Once they cure, they're no longer a threat.
woodnerd is offline
Sears Craftsman Auto Scroller Saw BiggestT Wood Scrolling 18 09-15-2017 05:05 PM
Princess Auto Router Bits okanagan Router Bits - Types and Usage 20 12-24-2009 09:47 AM
Auto engines istracpsboss Lobby 1 09-19-2009 04:25 PM
