Porter Cable 892 router - Router Forums
post #1 of 19 (permalink) Old 03-03-2006, 08:00 PM Thread Starter
Default Porter Cable 892 router
I just bought one today at Home Depot. I was surprised to see that when I set it up it didn't have a Auto spindle ramp, like they used to. Does anyone know if they have done away with this nice feature. It enables you to use one wrench automatically when the router is at full height.
Thanks.
sbolton is offline
post #2 of 19 (permalink) Old 03-07-2006, 06:59 AM
I just bought an 890 series Saturday and it doesn't operate that way - didn't know they used to. Not a big deal, but it sounds handy.
Gilbear is offline
post #3 of 19 (permalink) Old 03-08-2006, 10:53 AM
Dan
Are you aware of the PC 890 router recall?
Dan is offline
post #4 of 19 (permalink) Old 03-08-2006, 12:08 PM
Hi Dan,
Yes, I was aware of it - but I carried the notice along with me and checked serial numbers before purchasing - mines all good! The recall applies to 890's sold between sometime in 2003 and Dec 2005 - serial no's are listed - it doesn't apply to all of them. Thanks for the heads up though!
After a lot of looking, comparing and hands-on, I decided on the 895 - putting the fixed base in the table and the plunge for hand-held use. I just liked the feel and motion on the height adjustment better than the Bosch. Would have gotten the Freud 1700 but really didn't like the on/off switch position or action, and again liked the adjustment on the PC better.
Now to start making some dust!!
Gilbear is offline
post #5 of 19 (permalink) Old 06-21-2006, 08:39 PM
I just bought the 892 and am in the process of putting it in my table. I am wondering if there is a way to have the height adjustment, speed control, and power switch all face the front of the table. I thought I had read somewhere that this was a feature of this router? It is going to be inconvenient to have to either adjust speed or height from the back of the router when under the table.
ShaneB is offline
post #6 of 19 (permalink) Old 06-21-2006, 09:56 PM
awh
I went though this a few months back... the 890 series router with a fix base that they sell as a standalone does not have the automatic-spindle lock - the one that's part of the kit with the fix & plunge bases does have the auto lock feature.... I took back the fixed base router and exchange it for the kit, I think it was only like $50 bucks more, but the auto-locking spindle is worth that alone!
awh is offline
post #7 of 19 (permalink) Old 06-22-2006, 01:10 AM
It always makes me smile to hear about people getting new routers. Please take the time to register your new routers at www.portercable.com and while you are there sign up for the newsletters. Be safe and enjoy!
post #8 of 19 (permalink) Old 06-22-2006, 04:25 PM
AxlMyk's Avatar
I have the PC 895PK kit with both bases, and can see no way for an auto spindle lock to function.. What makes it work? Is it something in the base that pushes the button in when you raise it when mounted in a table? Reaching around the router to push the button in can be a real pain..
AxlMyk is offline
post #9 of 19 (permalink) Old 06-23-2006, 04:01 PM
AxlMyk
I have many PC routers but I don't have one with the Auto-Lock system.
I have Not taken one down to parts but I do use the change the bit out the top type router table and the pull the router with the base plate out type, they both work great.
It's quick and easy to pop in a new bit and you don't need to playing under the router table.
The one I like best is the change the bit from the top of the router table with the two bent wrenchs (off set type) in this way I don't need to remove the fence or reset the bit ,if I'm using a match set of bits. (male/female) type.
Note****most lock system, the harbor/shaft must be in the right spot so the lock can slip on the shaft,you may need to turn the bit/shaft (with the power off) so the auto-lock can slip on the shaft.just a long shot.
Bj
post #10 of 19 (permalink) Old 06-23-2006, 09:16 PM
AxlMyk's Avatar
The lock button works, but Tony mentioned an auto lock feature.. I'm now wondering if I got the Dual base kit with the standalone fixed base..
When I make my next trip to Marsh Power Tools, I plan on picking up a couple offset wrenches to make life a bit easier..
ShaneB;
I have my router mounted in the table so that the clamp and fine height adjustment is in the front.. I use a heavy duty light switch mounted in an electrical box mounted to the side of the table.. A cord comes out of the elect. box, and I plug the router into that.. The only thing in the back is the spindle lock button, and on-off switch.. Mounted in the table, I just turn the router switch on and use the light switch to turn it on-off..
AxlMyk is offline
No CD-ROM with Porter Cable 890 Router Combo Kit? Mort_Stevens Table-mounted Routing 11 08-29-2006 12:44 PM
Mounting Porter Cable 892 Fixed Base to Router Table Pack52 Table-mounted Routing 4 02-14-2006 04:50 PM
Porter Cable Plunge Router rbloar Tools and Woodworking 1 01-16-2006 11:38 AM
porter cable router bits delroy33 Tools and Woodworking 1 10-14-2004 05:37 PM
