Delta 6 inch long bed joiner problem. - Router Forums
post #1 of 6 (permalink) Old 09-17-2010, 07:32 PM Thread Starter
Metalhead781's Avatar
First Name: Randy
Thumbs down Delta 6 inch long bed joiner problem.
I've double checked everything including putting a level on both ends of the bed but my joiner isn't leave a straight edge. It's square but the edge is bowed. Even on a straight piece of material that i'm just cleaning an 1/8" off. Any suggestions?
Randy
Metalhead781 is offline
post #2 of 6 (permalink) Old 09-17-2010, 07:52 PM
dutchman 46's Avatar
First Name: Howard
Check to make sure that the back bed is level with the cutter. Thats what I would start with.
John 3:16
dutchman 46 is offline
post #3 of 6 (permalink) Old 09-17-2010, 11:14 PM
RustyW's Avatar
First Name: Rusty
Hey Randy, I saw a very good video on jointer setup, at Wood Whisperer. Here is a link.
Tool Setup | The Wood Whisperer
Rusty
If You Want It Bad, You Get It Bad The Worse You Want It, The Worse You Get It
RustyW is offline
post #4 of 6 (permalink) Old 09-18-2010, 09:50 AM
AxlMyk's Avatar
That is the most important setting. With a straightedge on the outfeed table and over the knives, rotate the head to verify the straightedge moves the same distance, on both ends of all the knives.
When I change knives I use this method to set them. I will get all the knives, at both ends, to move the straightedge 1/8". When done, I adjust the outfeed table up to level with the knives.
AxlMyk is offline
post #5 of 6 (permalink) Old 09-18-2010, 10:33 AM
Thanks Rusty
That's a great video a bit long but great..
post #6 of 6 (permalink) Old 09-18-2010, 06:22 PM Thread Starter
First Name: Randy
That was exactly it. I checked to make sure the bed was aligned and checked level on both infeed and outfeed but that i didn't check.
Randy
Sold: New Delta Bandsaw 14 inch Tommyt654 Woodworking Classifieds 3 05-01-2010 01:19 PM
Skil 1825 quarter inch collet problem arde New Member Introductions 9 06-21-2009 05:40 PM
Indestructable kids bed KoLdArKnEsS Show N' Tell 4 09-11-2006 09:24 PM
