HVLP sprayguns - Router Forums
post #1 of 17 (permalink) Old 09-18-2010, 12:36 PM Thread Starter
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Default HVLP sprayguns
Hi guys
Does anyone have any thoughts on these please?
Professional Automotive HVLP Spray Gun Kit
Cheers
Peter
istracpsboss is offline
post #2 of 17 (permalink) Old 09-18-2010, 12:57 PM
First Name: Mark
Peter,
I don't have those guns but mine are very similar. I use mine all the time and love them. The biggest thing to be concerned with is, what are you going to spray with them and do you have the right tip size. I would look up and see what tip would be best for your applications. The 1.8 tip may be too small for the things you want to do. I use a 2.0 and a 2.5 tip on many of my projects. So if you do buy them make sure you can get bigger tips.
Here is an ebay gun that talks about tip sizes.
Pro 2.5mm HVLP SPRAY GUN-Auto Paint Primer-Metal Flake: eBay Motors (item 190445334473 end time Sep-19-10 01:01:39 PDT)
Mark Sternberg is offline
post #3 of 17 (permalink) Old 09-18-2010, 03:26 PM
Hi Peter
That's a nice set, I don't have that set but I have the older model and it works well but when they say it's automotive type they are saying you must knock the mix down so it can be used in the gun so that why I started to use a true HVLP system, less than 5 lbs.psi and it will put down just about anything you put in the gun right out of the can a lot of the time I don't put it in the cup I just stick the stem in the can and shoot . (HF item at about 60.oo )
The HF system is on the low end but the price range is right and I would stack it up to many of the high price ones..it's that good...and is a snap for clean up..
see below
Originally Posted by istracpsboss View Post
Hi guys
Cheers
Peter
post #4 of 17 (permalink) Old 09-18-2010, 03:51 PM
dutchman 46's Avatar
First Name: Howard
Hello Peter! I am not sure how they would work, The viscosity of auto paints are different that our wood finish. The guns can also be pretty grumpy things, If the material Your spraying isn't just right, it will not spray. Coming from the auto industry, We tried many different professional guns, and only a few guns would lay out a finish that wasnt runny, or full of orange peel. Taking what I have experienced with the guns almost 10 years ago, I would make sure that if it didn't work to Your satisifation, You would return it. That is how i would approach it.
John 3:16
dutchman 46 is offline
post #5 of 17 (permalink) Old 09-18-2010, 04:31 PM Thread Starter
Country: Croatia
First Name: Peter
Thanks guys. Loved Bob's filtering stand. I hadn't realised it was necessary to filter the paint. I'd be using it for finishing wooden items with water based paint. I couldn't find Bob's Chicago Electric HVLP kit. It looks like they may have discontinued it.
Cheers
Peter
post #6 of 17 (permalink) Old 09-18-2010, 05:22 PM
Hi Peter
They still have them Levon got one about 2 weeks ago from HF..
http://www.harborfreight.com/high-vo...kit-44677.html
Cheers
Peter
post #7 of 17 (permalink) Old 09-18-2010, 06:24 PM
First Name: Mark
Peter,
I bought one of those chicago electric hvlp sprayers a couple years ago. They will not shoot latex paint, you have to thin it down to much to even get it through the gun and even further to make it spray without orange peel by then the paint is no good. Mine sits on a shelf. I do use the air pump to blow up air mattresses though it works great for that.
post #8 of 17 (permalink) Old 09-18-2010, 06:29 PM
Hi
The one I got came with the tip for latex paint and it will shoot the latex easy no extra water needed.. like it said almost anything but Not tar.. but almost..
But I didn't buy to paint my house it's not that type..
http://www.amazon.com/Graco-Airless-...4853577&sr=1-6
http://www.amazon.com/Wagner-9155-Ai...4853962&sr=1-5
I should post a snapshot of the porch furniture , the BOSS painted all of it last week with the HF unit and I mean all of it about 1 1/2 gals. of white outside latex paint.. She did a great job but she almost rope me into it..but she can paint better than me.. hahahahahaha
post #9 of 17 (permalink) Old 09-18-2010, 06:56 PM
First Name: Mark
I wish mine came with that tip!
post #10 of 17 (permalink) Old 09-18-2010, 10:48 PM
My air compressor hasn't got the volume to push a HVLP gun so I sprung for an Earlex 3500 and have been well satisfied with it. Sprays latex and oil stain with no issues.
EARLEX HVLP HV3500 SPRAY STATION (AVAIL 4/15/2010)
John Schaben
jschaben is offline
Inexpensive HVLP systems Thrifty Tool Guy The Finishing Touch 25 02-19-2010 03:25 PM
HVLP and Poly acrylic Thrifty Tool Guy The Finishing Touch 12 11-30-2009 12:15 PM
Wanted: Inexpensive HVLP systems Thrifty Tool Guy Woodworking Classifieds 5 09-14-2009 05:22 PM
HVLP Spraying LuisC The Finishing Touch 4 04-23-2009 09:48 AM
Hvlp jer760 The Finishing Touch 3 04-02-2008 10:38 PM
