Fixed base router to plung router - Router Forums
post #1 of 4 (permalink) Old 09-20-2010, 09:52 AM Thread Starter
paulwc's Avatar
First Name: Paul
Default Fixed base router to plung router
I bought a new Skil combo pack it's easy to change out but just what purpose does the plung router set up do, So far as I can tell this is a great router deal has lots of new and lates featers.
paulwc is offline
post #2 of 4 (permalink) Old 09-20-2010, 10:23 AM
Hi Paul
The plunge router lets you have full control of the depth of the router bit..plus much more.
post #3 of 4 (permalink) Old 09-20-2010, 10:44 AM
RJM60's Avatar
First Name: Robert
A plunge router permits starting and stopping a cut inside a work piece - i.e. you don't have to start from the edge. Although it may be possible to "plunge" a fixed base router, it would be very difficult to control the tilt of the router as you plunge it, thereby producing a very rough cut - at least at the start. There's probably also a significant added risk of injuring yourself; or damaging the tool, or the work piece.
One example of a good application for a plunge router is a mortise. Mortises must be cut accurately for both function and appearance. Stopped dados are another example.
Also, a plunge router can be fitted to a router table without the need of a lift mechanism.
RJM60 is offline
post #4 of 4 (permalink) Old 09-21-2010, 09:27 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
All the above, PLUS with a plunge router, releasing pressure allows the cutter to retract into the safety of the housing, therefore making the plunge router far safer for non-professionals.
Harry
harrysin is offline
plunge or fixed base bellaw Table-mounted Routing 16 01-08-2014 04:49 AM
Triton Router Base Plate garbo.hunter Triton 10 08-09-2013 09:00 AM
Skil 1/4" Fixed Base Router ? MuzzleMike General Routing 1 02-23-2010 11:07 PM
Craftsman 17543 Combo Fixed Base Height Adjustment Gator95 General Routing 14 11-29-2008 03:30 PM
Converting fixed base to plunge base. -Sam- Portable Routing 4 09-30-2004 03:53 PM
