Veritas Hold Down Clamps Alternative Makes? - Router Forums
post #1 of 3 (permalink) Old 09-24-2010, 10:18 AM Thread Starter
Gaia's Avatar
First Name: Peter
Default Veritas Hold Down Clamps Alternative Makes?
Hi,
These Veritas clamps,
Lee Valley Tools - Important Announcement
Are available in the UK but strike me as being very expensive. Are cheaper alternatives available? The nylon ones are fine, Buy Axminster Quick Action Bench Clamps from Axminster, fast delivery for the UK
for use in my carving bench, which will be my first woodworking project. The Veritas version might come in handy clamping down the work piece right on the edge, instead of on top of it.
Are there cheaper types of clamps that would do the same job?
Ta,
Peter.
Gaia is offline
post #2 of 3 (permalink) Old 09-24-2010, 10:46 AM
RJM60's Avatar
First Name: Robert
Originally Posted by Gaia View Post
Hi,
Ta,
Peter.
The 2 clamps you reference work differently. The Veritas uses the threaded shaft (via a bending moment) to connect the clamping force to the workbench while the plastic one requires that the back end of the clamping bar is supported. This support connects the clamping force to the table (threaded shaft is only in tension - no bending). This feature (of the plastic one) is what permits using the weaker plastic material in the shaft (i.e. only tension - no bending).
In addition, the Veritas clamp can be used from just the top side of the table (very handy) while the plastic one will require attaching the nut to the shaft under the table (can be cumbersome). Also, the Veritas will provide a greater height reach.
Since the Veritas is like an adjustable dog hole clamp, you could just use a dog hole clamp like this one: dog hole clamp if you have a suitable workbench (you would need a sufficiently deep hole for it to work right). These are very quick to lock and release (tap with a mallet) but might be prone to damaging the workpiece unless an intermediate protective piece of wood (or something) is placed under the clamp pad.
RJM60 is offline
post #3 of 3 (permalink) Old 09-24-2010, 12:28 PM Thread Starter
Gaia's Avatar
First Name: Peter
Ok, thanks.
Gaia is offline
UK Availibility Of Nylon Hold Down Clamps Gaia Tools and Woodworking 9 09-26-2010 03:02 PM
Hold down clamps vapochilled Jigs and Fixtures 1 02-06-2008 07:56 PM
An alternative way to hold stock harrysin Guide Bushings and Templates 5 02-18-2007 02:47 PM
Toggle Clamps (Update) Pop_pop1 Table-mounted Routing 1 08-29-2005 06:52 AM
T Track Toggle Clamps Pop_pop1 Table-mounted Routing 4 07-29-2005 02:22 AM
