Ryobi plate joiner - Router Forums
post #1 of 2 (permalink) Old 09-26-2010, 08:24 PM Thread Starter
Aquadan005's Avatar
Default Ryobi plate joiner
I have a Ryobi plate joiner (model JM80)my wife bought me as a birthday present a few years ago. I haven't had a chance to use it yet as shortly after I got it I had to have major back surgery. I was looking at it the other day and I noticed that when you press the base against a board and begin cutting the slot, there is some play between the base and the cutter. Is this normal to have some play there or should there be no play at all? How will this affect the joint? I'd guess there is about 1/32" (worst case guess) movement of the blade up and down.
The early bird catches the worm
But the second mouse gets the cheese!
Aquadan005 is offline
post #2 of 2 (permalink) Old 09-26-2010, 09:19 PM
I have a Ryobi biscuit joiner (different model) and have not noticed any play.
I would check to see that all the screws are tightened up.
Sydney, Australia
jw2170 is offline
Base Plate for Ryobi Router... Drog822 Portable Routing 39 02-20-2012 12:05 PM
