Dowel sizer and groover - Router Forums
 1Likes
  • 1 Post By bandsaw barry
post #1 of 2 (permalink) Old 10-14-2010, 02:34 AM Thread Starter
bandsaw barry's Avatar
First Name: Barry
Default Dowel sizer and groover
I am rarely satisfied with the fit of dowel diameters available, especially when supposed metric sizes are still imperial.
I size my dowels by chucking a length in my drill after chamfering the ends and running them through an offcut of flat mild steel which has been drilled with the nominal sized hole. If the result is still too snug, I'll repeat on a slight angle until I'm happy with the fit. I believe that the compression will be expanded by the water based PVA as per plate joiner biscuits.
To machine the glue escape groove, I fit the dowel into a block of scrap and run into the bandsaw blade.
Murtu01 likes this.
bandsaw barry is offline
post #2 of 2 (permalink) Old 10-14-2010, 12:05 PM
RJM60's Avatar
First Name: Robert
... or you could get a few imperial size bits and use the dowels as is ...
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
