Triton 2000 & Depth Of Cut Of Saw Blade - Router Forums
post #1 of 5 (permalink) Old 10-20-2010, 02:37 PM Thread Starter
Gaia's Avatar
First Name: Peter
Default Triton 2000 & Depth Of Cut Of Saw Blade
Hi all,
I have a Triton 2000 Workcentre and have put a Triton TA235CSL 235mm, 91/4 inch
circular saw into it. Also put a height winder attachment into it. The maximum depth of cut we get is dead on 2 inches! We have cut some timber it all seems to work OK.
Two inches max depth of cut, can't be right though? I got a 9 inch saw, to get I thought, at least 4 inches depth of cut set in a saw table, please advise?
Peter.
Gaia is offline
post #2 of 5 (permalink) Old 10-20-2010, 04:27 PM
dutchman 46's Avatar
First Name: Howard
Hello Peter! Welcome to the Router Forums. Glad that You could join us. I have never seen a saw like Yours, I will watch,while someone who can answer that, hopefully, someone will put a picture of Your saw on a post. I would like to see that.
John 3:16
dutchman 46 is offline
post #3 of 5 (permalink) Old 10-20-2010, 05:00 PM Thread Starter
Gaia's Avatar
First Name: Peter
Hello Howard,
Thanks for that.
Peter.
Gaia is offline
post #4 of 5 (permalink) Old 10-20-2010, 06:45 PM
DGK
First Name: N/A
Send a message via Skype™ to DGK
I've been studying the Triton line of tools and will be intrested in finding out why you're only getting 2". According to the specs:
dept of cut @ 90* = 82mm (3.2283 in)
dept of cut @ 45* = 58mm (2.2835 in)
DGK is offline
post #5 of 5 (permalink) Old 10-22-2010, 06:41 AM Thread Starter
Gaia's Avatar
First Name: Peter
Hi Donnie,
The specs, was the depth of cut 82mm @ 90*, was this with the circular saw mounted in the Triton 2000 Workcentre?
Sorry to read about your earlier hardships on your profile. I very much like your signature, could not agree more. If one lays down with dogs, one might pick up fleas
My best,
Pete.
Gaia is offline
Dovetail Depth of Cut Sherwood Portable Routing 10 11-19-2012 09:36 AM
cut depth rexdog Starting Off 2 02-15-2009 11:34 AM
TS blade with square corner cut? AxlMyk Tools and Woodworking 4 07-06-2008 05:20 PM
Freud 2200E -- How do I set it up for a measured depth plunge cut? Ladd General Routing 8 11-12-2007 03:23 PM
relationship between thickness and depth of cut Bear Starting Off 2 02-11-2007 08:44 PM
